reservoir stripped
Old Apr 13, 2007 | 05:38 PM
00y01e's Avatar
00y01e
reservoir stripped
I was removing the Pressure Sensor from the HPOP reservoir and the threads came out with it. Also may have the same problem with the access plug, as it won't come out. Any good fixes for this other than Helicoils?
Old Apr 13, 2007 | 08:04 PM
plowhand's Avatar
plowhand
Playing in the Dirt
New reservoir???? Sorry, not that I'm aware of. Maybe somebody else will have more helpful info for you.
Old Apr 13, 2007 | 08:37 PM
00y01e's Avatar
00y01e
Thanks for the response Plowhand, but I'm trying to avoid the $200 for a new one if possible.
Old Apr 13, 2007 | 08:54 PM
tjbeggs's Avatar
tjbeggs
I think its pipe thread. I don't know if they make helicoil's for pipe thead or not. if not and it is pipe thread you can remove the reservior drill it out and tap for the next pipe size up. then install a pipe bushing and reinstall the sensor
Old Apr 14, 2007 | 04:07 AM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
TJ is bang on the money, just remember to use a little teflon tape when you install your new pipe bushing
Old Apr 14, 2007 | 09:29 AM
barebackjake's Avatar
barebackjake
the threads are -4 oring boss. dont use teflon tape on the sensor it wont work if you do. it needs the metal contact for the ground. just use a little oil.
you might be able to run it out to -6 and find an adapter from a hydraulics shop. the top of the res isnt thick enough or strong enough to make it pipe thread plus pipe thread will leak since you cant use thread sealants.
if you know someone that can tig weld you can weld a plate ontop and tap it for the -4 and put the sensor back in. but since its some wierd press cast aluminum i dont know if you would be able to get all the oil out of the pores to weld it or even if that cast will weld.
Old Apr 15, 2007 | 12:26 AM
00y01e's Avatar
00y01e
Thanks for the ideas guys, I'll continue investigation.
Old Apr 15, 2007 | 02:07 PM
DAVID'S97F250HD
Jeez, nice catch, was'nt thinking
Old Apr 25, 2007 | 05:15 PM
00y01e's Avatar
00y01e
Got it fixed, used an EZ lok insert by drilling out the hole threading and inserting. had to cut off and polish the EZ lok to match the surface , then drill down slightly to allow for the O-ring but it works fine and won't strip out again. The ez lok has a 5/8-11 external thread and 7/16-20 internal.
Old Apr 25, 2007 | 05:37 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
OK you used the 651-19 EZ lok insert, but how did you fix to the reservoir, any kind of glue or what, an do you have any leaks? And what happened with with the access plug, was the same size?.
Thanks
Old Apr 26, 2007 | 04:19 AM
00y01e's Avatar
00y01e
The ez lok has a form of red loctite that they claim once installed will not move without applying a couple hundred degrees to it first. There are no leaks apparent so far (ez lok claims 6500 psi on their part) and the access plug is the same size but I got it out without damaging the threads.
Old Apr 27, 2007 | 11:20 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
aah. OK, understood, my friend 00y01e
