OBD 1 Code 10
Old Apr 13, 2007 | 01:02 PM
88 f150's Avatar
88 f150
OBD 1 Code 10
88 f150 5.0 302 When I pull codes KOEO I get a code 10(?) followed by 11(system passed) I cannot find any reference to a code 10. Anyone know?
Engine running I get "8cyl" (indicating I am testing an 8 cyl) "46" (Thermactor air not bypassed during test) "13" (RPM unable to reach lower test limit) "77" Operator error "52" Power steering pressure switch circuit open
How do I address these codes? How is the thermactor bypassed? Is it the solenoid next to the coil pack? And is it supposed to be bypassed before testing? Is the "13" related to the thermactor not bypassing? Operator error? Should I take this personally? Wheres my error? Thanks
Old Apr 13, 2007 | 01:15 PM
andym's Avatar
andym
How do you get a zero when pulling codes? Does it not blink and you assume it meant zero?
Old Apr 13, 2007 | 01:22 PM
88 f150's Avatar
88 f150
I have OBD1 reader that gives a digital readout
Old Apr 13, 2007 | 01:24 PM
andym's Avatar
andym
Is this the one you bought on ebay for $3? If so, I think I found your problem - your code reader is a POS. There are no zeroes in Ford ODB-I codes. Have you tried the paperclip method?
http://broncodata.com/tech/codes.htm
Old Apr 13, 2007 | 02:06 PM
88 f150's Avatar
88 f150
There is nothing wrong with the reader. I called the mfg. and the 10 is the "code reader system passed" it is not a ford code.
Old Apr 13, 2007 | 02:43 PM
88 f150's Avatar
88 f150
correction : Before the computer sends the second group of codes to the code reader, it first sends a "separator code" (code 10) to separate the first group of codes from the second group.
Old Sep 22, 2021 | 08:44 PM
JJLOPEZ's Avatar
JJLOPEZ
Code 1
0P
_______--------------
(((CODE 10 MEANS CYLINDER #1 PROBLEM )
Old Sep 23, 2021 | 07:14 AM
JRC99's Avatar
JRC99
Talk about a necrobump! 14 years!
Old Sep 23, 2021 | 07:21 AM
JJLOPEZ's Avatar
JJLOPEZ
New generations have to keep these post alive !
Old Sep 23, 2021 | 07:55 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by JJLOPEZ
0P
Incorrect. An OBD-I / EEC-IV system from 1988 does not give you specific cylinder faults. The code 10 solution was addressed in posts 5 & 6.
vjsimone
Mar 13, 2019 08:53 PM
maribou912
Feb 10, 2017 02:34 PM
BroncoBuddy
1978 - 1996 Big Bronco
15
Nov 4, 2003 10:36 PM
dbuck50
Oct 30, 2003 01:54 PM
dbuck50
Oct 30, 2003 12:32 PM
