Chip installation ??
Old Apr 13, 2007 | 12:53 PM
sean23johnson's Avatar
sean23johnson
i got my chip yesterday and i am going to install it today. my question is when you rub off the silicon coating on the contacts is it ok to also rub off the copper coating too?? i ask because i have gotton mixed reviews and i already rubbed off some of the copper and exposed the silver.
Old Apr 13, 2007 | 02:16 PM
SolidGround's Avatar
SolidGround
You want to remove the silicone ONLY, a little copper missing shouldn't hurt. My contacts are missing copper all over them (from chips being in and out). So far no problem.
Old Apr 13, 2007 | 02:23 PM
powrstrkn''s Avatar
powrstrkn'
I used paint thinner and a scotch brite pad , dont take off the copper, just the silicon.
Old Apr 13, 2007 | 08:01 PM
jtharvey's Avatar
jtharvey
Here's what I got from Jody. The contacts on the board are copper, but covered with some solder for a better connection to a chip. If you rub too hard, you will take off all the solder and the bare copper will show. The color will change from silver to the bright copper color. THIS IS BAD - DO NOT REMOVE THE SILVER DOWN TO THE COPPER. If you do, the connection between the chip and the board could be comprimised.
If the silver does get scrubbed off, there is a fix and it can be done successfully, but it's tedious...trust me on this one. If you get down to bare copper, the contacts have to be "retinned" with some solder to ensure a good connection with them and the chip. One has to be careful when doing this though as to not damage the board by overheating the contacts and melting the connection between the contacts and the board, rendering the board useless.
Point is, take off the silicon lightly clean the silver on the contacts, but don't scrub too hard.
andres0517
May 3, 2014 07:56 PM
NaviOn24s
Nov 18, 2004 11:37 PM
maticuno
1983 - 2012 Ranger & B-Series
Dec 26, 2003 08:10 AM
tarkon
Aug 6, 2003 09:52 AM
chads94
1978 - 1996 Big Bronco
Mar 12, 2003 09:11 PM
