1978 - 1996 Big Bronco
tires rubbing
Old Mar 11, 2003 | 10:39 PM
chads94's Avatar
chads94
tires rubbing
i just installed 35X12.5 tired on my bronco, when i turn the rub on the plastic peice on the bottom of the bumper..does anyone know how to remove that peice without breaking it? i don't want the tires ripping it off..thanx in advance
94 Bronco
302 103,500
4inch Rancho lift
Jet chip, Gibson headers
K&N FIPK
Old Mar 11, 2003 | 11:25 PM
SmaulzEB's Avatar
SmaulzEB
tires rubbing
If it's what I think you're talking about, should just be a few bolts. Crawl up underneath and take a look.
Old Mar 11, 2003 | 11:29 PM
chads94's Avatar
chads94
tires rubbing
They don't look like bolts...they almost look like rivets.....stupid haynes manuals don't help me at all lol
Old Mar 11, 2003 | 11:46 PM
chads94's Avatar
chads94
tires rubbing
Ok i found out that they are rivets holding it on, how do i remove rivets? anyone know?
Old Mar 12, 2003 | 01:30 AM
8996EBBroncos's Avatar
8996EBBroncos
tires rubbing
You can drill them out or just shim the bumper out a few inches.
Old Mar 12, 2003 | 08:16 AM
diggum's Avatar
diggum
tires rubbing
Hey!
I have the same size tires and instead of drilling every rivet out he is right just get a sharp knife and cut a few inch. out of it. it is a soft plastic it was a 2 min job and it made a huge difference.
Old Mar 12, 2003 | 08:39 AM
BroncoMTR's Avatar
BroncoMTR
tires rubbing
Just trim the part closest to the tire. There's a line where the plastic piece starts to turn in (more of a seam), it makes a good guide, and keeps the curve of the bumper. With a sawsall it'll take about 30 second to do the whole thing.
Old Mar 12, 2003 | 10:18 AM
Kemicalburns's Avatar
Kemicalburns
tires rubbing
i have that same rubber piece on the bottom of my bumper. mine is held on with plastic rivits, that are easily removed with a flat head screw driver and some downward force.
late
Old Mar 12, 2003 | 02:46 PM
ChrisAllen1090's Avatar
ChrisAllen1090
tires rubbing
Forget that stupid plastic valence. I just cut tore enough of mine off that I could get it stuck under the tire, then drove forward and let the truck tear the rest of it off. Just get rid of the whole piece. It makes the front stance look so much better.
Old Mar 12, 2003 | 05:36 PM
33bronco's Avatar
33bronco
tires rubbing
use A sawzall
Old Mar 12, 2003 | 09:11 PM
superbronc92's Avatar
superbronc92
tires rubbing
rip it off, rip it off, rip it off, rip it off, rip it off,...and anyway ..looks better.....plastic is weak... does not make truck look tough....just my opinion
mblayton
Exhaust Systems
16
Nov 10, 2011 12:37 AM
94WhiteF250
Oct 2, 2008 08:16 PM
99 Ford
Exhaust Systems
Apr 21, 2006 10:08 AM
BroncoMTR
Exhaust Systems
Aug 3, 2003 09:05 PM
bronco_jim
Feb 27, 2000 09:12 PM
