problems 03 7.3
Old Apr 13, 2007 | 07:26 AM
rjzook's Avatar
rjzook
problems 03 7.3
I have a 2003 F350 7.3. The problem is the first part of 1/4 inch of the gas pedal it hesitate alittle bit. Even while cruising. The dealership can't find out what's wrong with it. It doesn't throw a code. I have changed the cam sensor that didn't work. Any suggestion would be appreciated.
Old Apr 13, 2007 | 07:30 AM
bdrummonds's Avatar
bdrummonds
Have you changed the throttle position sensor on the pedal?
Old Apr 13, 2007 | 07:32 AM
rjzook's Avatar
rjzook
No I will try that.
Old Apr 13, 2007 | 07:51 AM
Pocket's Avatar
Pocket
The TPS is part of the throttle pedal assembly, so you can't just change out the TPS by itself.
On most trucks, it's normal to have no response on the pedal for the first 1/4-1/2 inch. However, once you do get throttle response, it should be smooth and easy. If you roll into the pedal, get a response, then it suddenly cuts out and tries to idle, then the only fix is to replace the pedal assembly. You can pick it up here for $120, and the swap will take you 15 minutes.
Old Apr 13, 2007 | 08:00 AM
rgconway's Avatar
rgconway
Rather than changing the TPS, it should be easy to test. It is a potentiometer (pot) with 3 connections. You can test the pot with an ohm meter by connecting across pairs of pins and moving the lever through full travel as follows: (Pin numbers from EVTM, not verified)
Pins 1-3 fixed, steady resistance
Pins 1-2 and 2-3 resistance should vary SMOOTHLY thru the full range, move the lever slowly looking for any breaks. Focus on the range where you have the problems, looking for a break or dead-spot.
If you get a clean sweep, I would conclude that the TPS is OK.
HTH,
Bob
Old Apr 13, 2007 | 09:44 AM
pullinair's Avatar
pullinair
Jody can fix it for you!
Just a side note, I have that quarter inch "no go feeling" when I am in stock mode. As a matter of fact I always had it even when the truck was bone stock. But the power comes on when you get past it. Then as soon as I swith to the 60hp or 80hp programs, the pedal is real touchy. Switch back to the stock and it is there again.
I think it all attributes to the space left for timing advancement and the room to add fuel to the engine in the CPU.
I have realy been dealing with this pedal feeling in stock mode when commuting to school everyday. I leave it stock mode becuase the engine doesnt come up to temp in a 5 mile one-way trip. ( I do not know where I inhereted this patience from!)
The first time I have even used any of Jody's programs in the past six months was last weekend when I had a long trip down to moms house and the engine had time to warm up. It was like getting Jody's chip for the first time all over again!
Old Apr 13, 2007 | 10:38 AM
rjzook's Avatar
rjzook
Thank for everyone's input.
