I am getting around 12.5-13.5 MPG's which really pisses me off. I am all stock and seriously thinking about banks air intake/filter and banks otto6/PDA. Any thoughts
Try changing brands of fuel. I went with a more expensive brand and I get 15 in the city. Before the change I got 13.5 at best.
Ryan,
Would it be safe to say it would also cut down on engine problems as well?
Herb
Stunningly, yes Herb it would, everything is realative, less ash fired on top of the piston, less trash run through the injectors, pump, less fuel burned, menas less fuel to end up in the oil, ect. ect. If 95% bio was an option for modern day injectors, and we could coax 20-25 mphof every light duty diese truck on the interstate, the 07 mandates would never have come to pass, cause your still killing 2-3 birds with one stone. 1 gallon of diesel produces so much pollution. The tree huggers and activists could care less how far you drove on a gallon of diesel, they just want to know what the emissions were for said gallon. That is the problem with liberals and environmentalists, they fail to see the whole picture.
I am getting about 17-18 around town on our econ/race tune and about 20/21 mpg on the highway but i think alot has to do with the completely stock truck other then the tunes and gauges. if it was two wheel drive i might be able to get better mileage or if Matt did beat the crap out of it when he drives
What is odd is that larger injectors seem to return about 2 mpg and even some of the really smoky files get better MPG. It doesnt make much sense as to why more fuel would equal better mpg but we are thinking it my be better atomization of the new nozzels and the high injection pressure commanded that is making the system more efficant.
I have had 2 injectors replaced and my truck is 4x4 but I have seen no new gains in MPG. Do you think Banks is worth the investment. I also have larger tires than stock, 285's but I cant imagine it would make that much difference, especially since I had the same MPG's with the stock tires.
Are you saying that on a stock 4x4 truck, larger injectors alone would noticeably improve mpg in typical highway driving (no towing)? Would an improved fuel feed also be needed (like F.A.S.S.)?
Jermey, I think you guys are on to something, I talked to Matt about this the other day, all I can come up with is how untuned, or innefficient the stock system really is, in compairison as to how precise a HEUI system can perform. The potential is there, you guys might starting to tap into it.
