plug gap questions
Old Apr 12, 2007 | 05:49 PM
F6Guy's Avatar
F6Guy
plug gap questions
I could use some help guys. I just installed a pertronix ignitor in my distributor along with a pertronix flame thrower HV coil with a 60,000 volt output and accel 8.8 plug wires that have 150 ohms/ft rating. My plug gap is set at the stock recommended gap of .025". I should be able to open it up my question is how much? Is there a formula or do I use the old set and drive it method?
Old Apr 12, 2007 | 06:39 PM
mechmagcn's Avatar
mechmagcn
With that setup, I would recomend starting at .035. Most electronic systems use a gap of .035 to .060, so I would start at the lower end and go from there.
Old Apr 12, 2007 | 07:20 PM
raerjim's Avatar
raerjim
I'm no mechanical guru, but I don't recall any plugs gapped at .025". As Jeff said, I'd start with .035" and try it. How do the the electrodes and ceramics look after driving it for a while? What type and range of plug is it? I believe the Motorcrafts in my 351W are at .044", but I don't have a high zoot ignition system. (Duraspark II)
Old Apr 12, 2007 | 08:11 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Flatheads and most early 50's 6v engines used a gap of .025".
I am using an MSD distributor with a "normal" 12v coil on my flatty. I had the same question and went with .030" for the simple reason the Autolite plugs are set at that out of the box. Works fine. There's no burning advantage to a wider gap, just ratchets up the level of stress on the system.
Old Apr 12, 2007 | 08:59 PM
F6Guy's Avatar
F6Guy
Thanks. My ceramics were a little on the dark side before. I have not checked them out yet. I know that the ignition will only use what it needs to jump the plug gap, but my thinking was If I could use a bigger gap it couldn't hurt as flatheads have one of the worst combustion chambers ever designed as far as efficancy goes.
Old Apr 12, 2007 | 09:39 PM
53fatfndr's Avatar
53fatfndr
I'll relate my experiences with my rebuilt 400 in my '53. I'm running a full MSD ignition system... MSD 6A box, MSD Blaster-3 coil, MSD 8580 distributor, and 9 mm Ford racing wires. My plugs had a bit of a dark, rich color to them. I ended up opening the gap up from .035" (stock) to .050"....which is what MSD recommended. At .050", the spark plugs "lightened" up. My advice is to experiment with the gap in .005" increments. I also went to a colder plug, from an Autolite 25 to an Autolite 24. Just keep in mind that increasing the gap on your plugs will put additional strain on the other components in your ignition system.
Old Apr 12, 2007 | 09:42 PM
F6Guy's Avatar
F6Guy
I realize that which is why I kinda went for "overkill" on everything else. Thanks for the input guys.
Old Apr 12, 2007 | 09:49 PM
53fatfndr's Avatar
53fatfndr
That pertronix coil of yours is pretty hot. It's packing 25% more punch than most other aftermarket stuff. The average aftermarket coils seem to be right around 45,000 V.
Just an FYI, MSD also recommends a plug gap as to the compression you are running. The higher the compression, the smaller the gap. I realize you aren't running MSD, but the info should still be fairly usefull.
http://www.msdignition.com/7530html/info.htm
Old Apr 13, 2007 | 06:38 AM
raerjim's Avatar
raerjim
Yeah, what I know about flatheads and other engines of that era can be written on the head of a pin.. LOL
Old Apr 13, 2007 | 07:01 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I've always run at least .050 on any electronic ignition and any engine...
cjohn2000
32
Nov 5, 2012 01:35 PM
allstar940
Feb 17, 2009 06:08 AM
John - NNY
Mar 27, 2006 06:28 PM
JLb300
Jul 7, 2004 08:23 PM
prginocx
Feb 3, 2003 04:44 PM
