I have a 2006 f350 crew. It seems that I'm noticing the turbo taking longer to spool up than when the truck was new. I only have 16k miles on the truck. Its most noticable from a dead stop pulling out into traffic. I know that turbo lag is common and not necesarily a problem but its to the point that I'm holding my foot on the brake and pressing the accelerator to spool up the turbo in order to pull out into traffic. What's the normal turbo lag time for the 6.0? Is there a standard benchmark that the dealer will check it against if I bring it in for service?
Thanks for you thoughts,
Jeremy.
It takes less then a second to hit 10 psi of boost. My rpms will hit 2000 and the boost hits 10psi. Then the truck starts taking off. Once second does feel forever. And my truck is so heavy, I try not to chance anything by dead stop pull into traffic.
My turbo lag was significantly reduced after my MAP sensor was replaced. My MPG's went up a lot after the MAP, too. It maybe just a fluke, but helped mine. All of the sensors in the system work to provide information to the PCM... It may have been the weak-link.
Thanks for the info. so far. I'll time mine and see where it kicks in then post back. I'll try to swing by the dealership as well and see if they can check the MAP sensor.
Had this on one of mine, replaced 4 injectors and it was like new. Within a month it started doing it again, now it will barely get out of it's own way. Time to 2000-2200 RPM's is at least 5 seconds, sometimes up to 10. My other 2 are usually about 2 seconds max. It's had a new turbo and new EGR, despite the EGR being unplugged.
The dump box is being repainted right now. As soon as they're finished, it's going to a dealer and I am telling them the same thing as last time, "I don't want it back until it's fixed". Good thing I have some 7.3's that can be used in the mean time. At least only this one has been a royal pain in my butt and the other 2 have only had minor issues--STC fittings on both.
Providing everything is ok mechanically, I have found that if you so to speak roll into the throttle instead of wacking it to the floor it will accelerate much quicker...
Try the following, PLEASE do this with regard to others around you. Find a parking lot or simular area. Bring the truck to a full stop, keeping the brake on apply the pedal and bring the RPMs up to 1500. Watch the boost level and take mental notes of the PSI reading. The truck should build boost and increase the PSI as you increase RPMs. I find around 2000 RPMs the rear end breaks loose.
I'll double check to see for sure, I'd guess close to 15+PSI. I've held 10+/-PSI @ 1500 RPM waiting for the light. From what I have experienced while driving it seems as 10 PSI is the magic number to overcome the turbo lag.
Ok, my truck wouldn't burn out either but I am having turbo troubles...
If I blip the gas right before I shut the truck off I can hear the turbo spool down and it sounds like a box of gravel.... I guess it could be the engine fan but it produces a hollow grinding sound that I think is the turbo.
I have some 35's on now and couldn't get it to turn the wheels. I was pushing 7-10 PSI @ 1500 rpms. Once I got to 15 PSI pushing 2000rpms the truck was ready to break loose but the big tires were holding it back.
I can hear mine spool down as well on shutdown, but if it's a grinding noise it doesn't sound good. Remember the DP is a big metal tube and may cause the noise to sound worse.
Yea, It sounds like the turbo is kaput. It will sometimes under boost, then over boost plus the truck has an awful whine/hiss sound so it's headed to the dealer on Monday.
Dont mean to hijack this guys thread.
But can somebody tell me what happens when the turbo goes out. Is the truck still driveable but just wont go.. or are you pretty much stuck on the side of the road?
Thanks
