White smoke
Old Apr 12, 2007 | 11:45 AM
hoggester's Avatar
hoggester
Unhappy White smoke
Why is my truck still blowing white smoke?
I have replaced both head gaskets, changed the oil and coolent.
and it still blows white smoke. Does the timing have anything to do with it?
Old Apr 12, 2007 | 12:31 PM
quicklook2's Avatar
quicklook2
did you check your compression before you tore the engine apart?
did you replace or have the heads checked?
did you see where the leak was?
you need to give a whole lot more info.
Old Apr 12, 2007 | 01:07 PM
Diesel Man 03's Avatar
Diesel Man 03
He doesn't say that he rebuilt his engine that I can see.Possibly he has a cracked head or block.
Old Apr 12, 2007 | 02:05 PM
95Ford4x4's Avatar
95Ford4x4
give us more information, year, model, engine, is the white smoke the reason for replacing the head gaskets??
Old Apr 12, 2007 | 02:40 PM
Phillip Guidry's Avatar
Phillip Guidry
If auto trans with vacuum modulator............bad modulator letting ATF get sucked into intake..........then white smoke ???
Phillip
Old Apr 12, 2007 | 02:43 PM
95Ford4x4's Avatar
95Ford4x4
is that possible?? only vac modulated tranny he could have would be a c6.
Old Apr 12, 2007 | 02:56 PM
Phillip Guidry
You bet yuh 95ford4x4.....
Phillip
Old Apr 12, 2007 | 03:14 PM
95Ford4x4's Avatar
95Ford4x4
glad i never had that happen before, that would not be on the top of my list of suspects for smoke.
Old Apr 12, 2007 | 05:32 PM
hoggester's Avatar
hoggester
Arrow Re: white smoke
More info it is a 1988 F150 4x4 5.8L, it started to smoke and there was some coolent in the oil pan so I replaced the head gaskets. and reset the time and when it start up it was still smoking(white smoke). so I was wondering if the timing is off will it still smoke. If not what can it be.
Old Apr 12, 2007 | 05:43 PM
andym's Avatar
andym
There are some good suggestions in this thread. Did you rebuild the engine or just replace the head gaskets? Did you do a compression check on the motor?
If you replaced the head gaskets, then you either didn't install them right and they're still leaking, you have a cracked block or heads (did it overheat?), or as someone else suggested, there is ATF getting sucked into your intake via the vacuum modulator on the tranny.
It cannot be the timing. Incorrect timing can not cause white smoke.
