Hard start
Old Apr 11, 2007 | 12:36 PM
Bloodline_F250's Avatar
Bloodline_F250
Hard start
Every morning when I use my remote start it doesnt start because I needs to crack quite a bit to start. After you drive it it will be fine unless you let it sit for more than 9 hrs. Anyone have ideas on what could be going on.
Old Apr 11, 2007 | 12:42 PM
plowhand's Avatar
plowhand
Playing in the Dirt
I guess that it's still cold in CT. I would check the glow plug system for proper operation. GPR (Glow Plug relay) valve cover connections (burnt or bent pins/connectors) Ohm or use a test light for the glow plugs and under valve cover wiring harness.
bkcowboss's Avatar
bkcowboss
Does your remote start have a pause for the Glow plugs? was it working normal and then quit working?
Old Apr 11, 2007 | 06:55 PM
Bloodline_F250
yes it has a 15 sec pause for the glow plugs.
Old Apr 11, 2007 | 08:16 PM
96powerstroke's Avatar
96powerstroke
with your long start is it turning over really slow, like it has sat in extreme cold for a long time without being plugged in? if so clean the connection between the hot battery cable and starter, i just had the same issue and now it spins over real fast and starts like a champ.
Riley
Old Apr 11, 2007 | 08:54 PM
Bloodline_F250
ok thanks for the advice
Old Apr 11, 2007 | 10:55 PM
bkcowboss's Avatar
bkcowboss
Sounds like possibly a GPR starting to go south. When you go to start it tomorrow, jump the big terminals for 20 seconds then hit the remote start if it fires replace the relay
Old May 7, 2007 | 11:08 AM
Bloodline_F250
where can I the GPR other than the dealer and is there an upgrade than a stock one.
Old May 11, 2007 | 09:52 AM
Neal 97 250's Avatar
Neal 97 250
The gpr can be bought at most any parts store. I hear NAPA has a good one. There is an upgrade that would be best for people in colder climates but I can't seem to find it now I will keep trying to find info on it. Will keep you posted.
Old May 11, 2007 | 10:11 AM
bkcowboss's Avatar
bkcowboss
Hey if I was to do it again here is what I would do.
http://guzzle.rbmicro.com/s_gpr.html
Old May 11, 2007 | 11:01 AM
Neal 97 250
Ahhh. That is the one I was looking for. Thanx Bryan
Old May 11, 2007 | 11:58 AM
bkcowboss's Avatar
bkcowboss
no prob thats what im here 4
Old May 11, 2007 | 02:21 PM
Bloodline_F250
thanks for the info
GORDEN1234
2009 - 2014 F150
Jan 20, 2015 10:20 AM
59203shop
Sep 6, 2014 09:47 PM
brcwelding
Jan 30, 2012 07:57 AM
NovaKid69
Oct 11, 2006 08:49 PM
Manitoulin
39
Jul 17, 2004 11:54 PM
