1978 - 1996 Big Bronco
Catlytic Converter Question
Old Dec 22, 2001 | 01:18 PM
masterkiller214's Avatar
masterkiller214
I just had a 40 series flowmaster muffler put on yesterday and my
91 Bronco still sounds whimpy. I asked the exhaust tech if he could
make it sound a little better and he said to get a cat conversion
(take off both of the cats and replace with one high flow cat and
putting on bigger tubing there). He said it would cost about $250. Is
there a cheaper way of doing this and still keeping my bronco street
legal, like removing one of the cats or something? HELP ME PLEASE!
91 Bronco 302
Old Dec 27, 2001 | 02:12 PM
emboyd's Avatar
emboyd
In the past, I've seen Cats run for close to $100 or more. So, his $250 total price might be a little high, but it wouldn't be a cheap one. Too bad you can't just take off the cat and insert a straight pipe. That'd solve it all, eh.
Old Dec 27, 2001 | 07:43 PM
restorit's Avatar
restorit
High-flow cats have gotten considerably less expensive, and can be found in the $80 - $100 range. Your exhaust shop will probably not want to install one you bring in if he's wanting $250 for the whole job, so you may shop around and ask the different shops if they would install a converter you bring in. Some will, and some won't. The latter are usually concerned about the legality or quality of your part, so they're not necessarily concerned with you buying one from them. It all depends on the shop.
Old Dec 29, 2001 | 01:24 AM
TexasGuy001's Avatar
TexasGuy001
Remove your second cat and leave the first one there and run a 3 inch pipe from the first cat to your flow. Thats what I did to my 95 F-150 with a 302. It made a big difference in sound and it runs considerably better.
Old Jan 3, 2002 | 12:36 AM
masterkiller214
Hey thanks you guys. I went with the Car Sounds(MagnaFlow) high flow cat with the 3 inch tubing to the Flowmaster and its sounds and runs great. Thanks for the advise people.
Old Jan 10, 2002 | 08:02 AM
tapenick's Avatar
tapenick
I'm thinking of doing a similar conversion... did you replace the front "Y" convertor?
Old Jan 10, 2002 | 09:46 AM
adelyser's Avatar
adelyser
6CylBill
Exhaust Systems
May 16, 2008 06:21 PM
RobertJohn
Dec 26, 2007 01:57 PM
UGA33
Feb 1, 2007 12:37 AM
rshissler
Apr 19, 2005 08:55 PM
xbronco94
Exhaust Systems
23
May 27, 2004 08:24 PM
