trubo problems or help
Old Apr 10, 2007 | 04:57 PM
rob92761's Avatar
rob92761
i have an 00 ford f 250 PSD 7.3 with a 6 speed mauanl tranny. I have 4" exshaust with banks brake. I have super chips installed with high perfromance. I also installed banks quick trubo assembly. My problem is when i frist installed the quick trubo i was getting boost up to 24 psi now i am lucky is i can hit 20 more like 16 to 18. I do have exhasut temp gauge installed and i very seldom let it get over 900 degrees because i have inststalles post trubo
Thanks rob
F 250 7.3 PSD super chips, banks brake and exhusat, quick trubo, exhaust temp, trubo boost guage, tranny temp gauges, 192000 miles
Old Apr 10, 2007 | 05:49 PM
Pocket's Avatar
Pocket
That doesn't help much because it is post turbo temps that you are taking. I HIGHLY recommend that you mount that probe pre-turbo.
Now, for your issues, it sounds like you have a boost and/or exhaust leak. Start checking your CAC boots for leaks, cracks, or loose clamps. Also look at the exhaust manifold and up-pipes for any signs of leaks.
Old Apr 10, 2007 | 05:55 PM
rob92761's Avatar
rob92761
i have check the boots going to the inter cooler, and check clamps is there any way to check them instead of looking at them.
Old Apr 10, 2007 | 06:58 PM
Pocket's Avatar
Pocket
You can remove all 6 boots, clean them, inspect for cracks, and the re-attach them. The clamps should be pretty tight. As for the exhaust side, just look for soot build up. That will indicate the source of the leak.
Old Apr 10, 2007 | 08:57 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
With 192,000 miles it could be the injectors are getting tired. Could also be a worn out spring in the wastegate actuator.
Old Apr 11, 2007 | 05:33 AM
rob92761's Avatar
rob92761
I put in big head wastegate from banks when i installed the quik trubo
