leaking oil
Old Apr 10, 2007 | 12:52 AM
bawrestler's Avatar
bawrestler
leaking oil
I am leaking oil out of where the distributor and the block meet. Is there suppost to be a gasket of some sort or an o-ring some where? Any help would be greatly appreciated.
Old Apr 10, 2007 | 08:31 AM
ENCSDEI's Avatar
ENCSDEI
According to the book there is an O-Ring btween the drive gear and where the Dist. seats to the block. What type of vehicle do you have?
Joe
Old Apr 10, 2007 | 09:00 AM
jas88's Avatar
jas88
It's probably the lifter cover leaking, pretty common on these engines, just tighten the bolts to spec.
Old Apr 10, 2007 | 10:34 AM
bawrestler's Avatar
bawrestler
the truck is a 83 f-250 4x4 with a 4speed but the engine is out of a 75.
Old Apr 11, 2007 | 08:52 AM
kotzy's Avatar
kotzy
I may be wrong but isn't there an O ring on the distributor housing about half way down the machined part that slide in the block?
Old Apr 12, 2007 | 11:00 AM
bawrestler's Avatar
bawrestler
I pulled the distributor out and yes there was an O-ring on the distributor. Went to the hardware store bought a new O-ring, cleaned everything and no more leak. Thank you for the replies.
