Bolt size?
Old Apr 9, 2007 | 01:17 PM
terran05's Avatar
terran05
Bolt size?
could anyone point me in the direction where I could find the bolt size that bolts my clutch to the flywheel on a 77 351m 12 5/8 bolt circle. it has a np435 4 speed behind it.
Old Apr 10, 2007 | 11:38 PM
orich's Avatar
orich
Not that this is very much help but! Ford used 2 different ones 1" ford flywheel & 3/4" long for auto flex plate..Sorry that as good as it gets from my book about it.
Old Apr 11, 2007 | 05:37 AM
stuart1's Avatar
stuart1
They are a special bolt and only available through a dealer.
There is a shoulder that must be used and aftermarket bolts do not have it.
Old Apr 11, 2007 | 06:04 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Special 351M Bolt (Note: 400 is different) Ford Part Number:
6-355705-S .. Bolt, Pressure Plate to Flywheel 3/8" -16 x 31/32"
Don't forget the lockwashers.
Old Apr 11, 2007 | 12:20 PM
terran05's Avatar
terran05
Thanxs guys. where can I get those? does it have to be a dealer or can I get them from a fastener place? its the only thing holding it back from being drivable, its driving me nuts I need a mud truck!!!!
Old Apr 11, 2007 | 12:22 PM
NumberDummy
That is the actual Ford part number I posted, so a Ford and/or Lincoln-Mercury dealer will be your only recourse.
Old Apr 11, 2007 | 02:04 PM
gustang818's Avatar
gustang818
There are also aftermarket alternatives. The real auto parts store around here had a set of Mr. Gasket pressure plate bolts and lock washers (Part # 910) for me when I was trying to get my manual trans swap finished on a Sunday afternoon. I think they are listed on the package as Chevy bolts but they are the right grade, length and thread. I originally bought a package of ARP pressure plate bolts listed on the package as being for Ford but they were 5/16-18 and did not fit my application.
ARP also makes them and they can usually be found in your local speed shop. Be sure to get the right size and thread.
skidoorulz
Nov 4, 2014 12:53 AM
d-day
Dec 10, 2013 06:01 PM
Rich55
Dec 3, 2009 08:04 AM
Loganwildman
Apr 21, 2005 04:57 PM
