Big lope!
Old Apr 10, 2007 | 12:29 PM
empiretc's Avatar
empiretc
Yes, please update when you try it.
Old Apr 10, 2007 | 12:38 PM
SolidGround's Avatar
SolidGround
Just started it...Loped like hell but idling fine now. Going to drive it around and see what codes I can pull while giving it a hard time. This laptop has to go with me, so...
Old Apr 10, 2007 | 12:50 PM
greagin's Avatar
greagin
my neighbor has this same issue, i will be very interested to see what this outcome is. he also just changed the oil and used a gallon of lucas.
Old Apr 10, 2007 | 07:01 PM
SolidGround
I give up! Not really, just stumped on this one.
Anyone...
Any ideas...
Old Apr 10, 2007 | 07:12 PM
greagin's Avatar
greagin
i say check it for several days after the oil change and see what happens. are you running ULSD? do you use fuel additive?
Old Apr 10, 2007 | 07:29 PM
Uzumati's Avatar
Uzumati
Your running 4 gallons of rotella and 1 gallon of lucas? thats 5 qrts over full or just a typo.
Can you check ICP Voltage while starting and during the lope?
Pressure (PSI) Pressure (MPA) Sensor Voltage
0 0 .02v
200 1.5 .4v
400 3 0.73v
600 4 .96v
800 5.5 1.2v
1000 7 1.4v
1200 8 1.6v
1400 9.7 1.9v
1600 11 2.1v
1800 12.4 2.3v
2000 13.8 2.6v
2200 15.2 2.8v
2400 16.5 3v
2600 18 3.3v
2800 19.3 3.5v
3000 20.6 3.8v
Old Apr 10, 2007 | 10:00 PM
SolidGround
greagin, Yes on the ULSD, I only fuel at major truckstops, 125 gallons +/- a time.
Alan, NO typo, deep pan and big cooler = 20 quarts. Can check voltage in the morning, are you thinking oil pressure problem or possible disruption in the valve covers during injector change? I've had them off several times.
Old Apr 12, 2007 | 08:06 PM
SolidGround
Hasn't done it again... I don't know?!
Old Apr 12, 2007 | 08:20 PM
Uzumati's Avatar
Uzumati
I was thinking foaming oil or possible biased ICP
Old Apr 12, 2007 | 08:24 PM
SolidGround
I was thinking oil. First time I ever wanted a problem to return...but it wouldn't break my heart if it never did it again.
Old Apr 12, 2007 | 10:50 PM
empiretc's Avatar
empiretc
hate to say it, but told ya so. i found out the hard way. But that is what we are here for. Share our lessons!!
Glad you got her purring.
Old Apr 12, 2007 | 11:02 PM
SolidGround
Not sure I follow you here, maybe the Lucas thing?
Why, in almost 200,000 miles hasn't this occurred if caused by said additive.
Our shop truck gets the same (11 quarts Ro, 1 gallon Lucas), 125,000 miles, turned up good even has PMR's.
Our "work" truck has flipped the odometer, yes flipped as in turned over completely, and gets the same regiment.
I'm not sure this has anything to do with the 'additive.' Something didn't add up.
BTW, it doesn't purr, it GROWLS!
Old Apr 12, 2007 | 11:28 PM
  #28
empiretc's Avatar
empiretc
GROWLS, love to hear that!!
Every truck is different- My friend still uses 1 gallon of lucas in his truck at every oil change and has never had a problem. Mine just didnt like it.
AFAIK, figure out what she likes, and give it to her.. LOL (no pun intended).
Old Apr 13, 2007 | 11:15 AM
  #29
BowDown's Avatar
BowDown
Mine only romps if I start it without plugging it in below 30deg.
Could it just be an over fueling issue with a cold combustion chamber?
Old Apr 13, 2007 | 11:31 AM
  #30
clintbonnie's Avatar
clintbonnie
Your oil is not flowing freely to your injectors when it is cold.. I changed to Shell Rotella Synthethic 5w40 and have never had a romp since.. even when it is cold..
