Assuming that you have speed density EEC-V, you need to be very carefull as to camshaft mods.
I did the same thing with a 302, then had to do a MAF conversion to make it work. The SD does not tolerate much change. If you already have MAF, then go for it.
You do have some room to play with as far as the cam, but not that much, and if you do change the cam profile and keep the SD system, you will have some lean spots in the fuel maps, particularly towards WOT. You go too far like I did and the thing wont stay running at all below 1500 rpm. Or you can reprogram the SD computor to work with the cam, but I've never done that so I can't help ya there.
What kind of Gas mileage, would I be looking at. I'm not looking for a street rod to suck down gas, just a small upgrade on the internals.
That cam would be a heafty upgrade over stock, and it should improve cruising milage due to increased torque at low rpms. But, the 112 lobe seperation angle will require mass air to run properly. A similar cam with 114 LSA would work with the existing SD efi system.
112 degrees of lobe separation should be fine. It runs in my mind that is what ford used on the 302 in the SD EFI form. You have a couple degrees to play with as the computer is a little more friendly than the MAF computer. If you have a rich buddy that likes to tweak on cars they is a system know as TWEECER, it's a link that goes between the computer and the truck's/car's wiring harness and you can change the fuel map, and timing curve with a few clicks of the mouse.
No.. you got that backwards. The SD computer wants a minimum of 114 deg LSA while the more forgiving mass air system will work with 112 or even 110 deg LSA... depending upon how radical the cam is. Stock Ford SD cams are all 115+ LSA.
The 351efi cam is 114 degrees, from what I've read the SD is actually more like to run with the mods than the MAF system. They both have set parameters they operate by. The difference is the MAF system reads the air flow through the MAF sensor instead of the MAP sensor. The SD is preferred by most mustang guys because it's easier to tune.
..from what I've read the SD is actually more like to run with the mods than the MAF system. The SD is preferred by most mustang guys because it's easier to tune.
Again.. that's contrary to everything I have read and seen with the mustang guys I know.
Which.. if you think about it... means that the mass air system actually measures the airflow passing through a motor realtime and can adjust fuel and timing to it. The best the SD system can do is calculate(guess) the proper fuel mixture based on pre determined maps and a vacuum(manifold pressure) signal, which in not nearly as accurate. A 5.0 mass air computer will run a 351 no problems.. I have been driving it for 7 years. Both these motors will produce very similar vacuum signals, but the A/F ratio would be excessively lean on an SD computer without a chip or other programmer to tell the computer the engine displacement is larger.
Yes, this is true. I also remember reading somewhere (can't remember where off hand) that the SD system has a richer base mixture as well.
I'm surprised that your 351 runs with the 302 computer. I've heard several people on here say that they had to tune the MAF computer to get it to run right. Which computer are you using the A9L?
I believe it's the A9P.. it's been so long since I have seen it I can't remember. It's the Ford Motorsports mass air kit using the mustang computer for automatic transmissions.
You have a couple degrees to play with as the computer is a little more friendly than the MAF computer. .
I know from first hand experience that the SD computor will not tolerate much change in camshaft at all where as the mass airflow system will adjust itself well to camshaft changes. My cam in my 302 has 110 LSA and I have the FMS mass air kit and unless my Interro 5 gas analyzer is misleading me my air fuel mixture is right on and my motor is running great. The SD system would not even run that motor below 1500 RPM and when it was running the AF ratio was very lean.
The reason that Ford is able to market and sell these mass air kits is due to their ability to adjust to mods like this.
