glow plugs
Old Apr 8, 2007 | 02:10 PM
the weez's Avatar
the weez
glow plugs
I have 125k on my plugs and think it's time to change them out. Is this something I can do in my garage and how do I do it? Any ideas on cost?
weez
Old Apr 8, 2007 | 02:22 PM
bigbadwolfe's Avatar
bigbadwolfe
about 80 bucks for the glow plugs make sure you get the motercraft ones part#zd11and only them and yes it is something you can do yourself at home
Old Apr 8, 2007 | 03:03 PM
10bands's Avatar
10bands
See "Glow Plug Removal" on this page.
http://pages.prodigy.net/stevebaz/_i...az/index3.html
Old Apr 8, 2007 | 04:13 PM
bridgeman's Avatar
bridgeman
Is the truck hard to start when it's cold? Just because you have 125K does not mean you have to change the glowplugs, save yourself some busted knuckles if its not starting by changing the gpr and making sure all the contacts are clean, I spent 3 hours per side changing mine only to find out they were all still good (140K mi) all I needed was a new gpr.
Old Apr 8, 2007 | 06:09 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Like bridgeman said, don't change them just to be changing them. Ohm them out first to see if you have any bad ones. Also check the gpr for proper opertation. Let us know if you need any help, we're here for you.
Old Apr 8, 2007 | 07:06 PM
the weez's Avatar
the weez
ok thanks for the advice. Truck has been hard to start if I don't plug it in, even when it only gets down in the low 40's or so. Lots of white smoke and it cranks fine as the batts are new.
I bought a new GPR and will switch it out next weekend but I just figured might as well do the plugs at the same time.
Is there anyway to tell when they go bad besides checking the ohm's?
Old Apr 8, 2007 | 07:16 PM
powerstroked162's Avatar
powerstroked162
if it wont start after you got a new GPR then they're no good. lol, good luck!
Cowboy Steve
Old Apr 8, 2007 | 07:20 PM
tjbeggs's Avatar
tjbeggs
you can use a test light also to test them
Old Apr 8, 2007 | 07:29 PM
powerstroked162
pull em out and leave em hooked up and put them in the palm of your hand and have someone roll the key switch on. that'll tell ya which ones work and which ones dont
Cowboy Steve
Old Apr 9, 2007 | 10:22 PM
Timmyjane's Avatar
Timmyjane
I have 253k on the original plugs. I did recently have to have the GPR and 4 out of 8 GP wiring harness connector ends replaced. But the GP were still good.
Old Apr 10, 2007 | 10:02 AM
bkcowboss's Avatar
bkcowboss
Test light like TJ said works good as a test. Hook the aligator clamp to the Pos battery terminal and then touch the outside pins on each of the valve cover plugs, 4 plugs 8 pins, light comes on, good plug, light doesn't come on, bad plug, or bad UVC wiring , either way you need to pull the Valve Cover and fix the issue.
Weez1
2004 - 2008 F150
27
Feb 24, 2012 10:58 PM
weez440
2004 - 2008 F150
Jan 8, 2012 02:02 AM
weez440
May 23, 2011 03:44 PM
