351 Swap
Old Apr 8, 2007 | 12:34 PM
Mountianeer's Avatar
Mountianeer
351 Swap
I have a 96 F150 with a 302 EFI auto trans, Not sure if it is E40D or what, but the tranny is being rebuilt as we speak with a shift kit. A buddy of mine who is a forum member has a 90-something 351 that has been rebuilt. We are pretty sure that it will bolt right into my 96, but since it is already out and exposed, what mods can I give her to help the performance. Anything and Everything Considered. I do some moderate towing from time to time, and she is mostly a daily driver, but does see the mud some. Thanks.
Old Apr 8, 2007 | 04:54 PM
Conanski's Avatar
Conanski
None of the factory cams will give you all the potential from the motor, the pre '94 was really smothered badly. If you have one of these older motors with the flat tappet cam, swap the factory bump stick for the Comp Cams 35-255-5. If you have a roller motor use the Comp Cams 35-349-8. If you feel up to it, the stock heads can benefit from some mild porting.. mainly on the exhaust side. See here... http://diyporting.com/
cd4e
May 24, 2017 11:36 PM
jwingra1971
Feb 3, 2017 09:08 AM
azazel_18_2
Engine Swaps
Sep 26, 2016 10:18 AM
macs40
Engine Swaps
May 17, 2016 09:44 PM
farlem99
1983 - 2012 Ranger & B-Series
Feb 16, 2006 08:08 PM
