Sponsored by: Real Truck
Please Help PITMAN ARM stuck
Old Apr 7, 2007 | 06:27 PM
capn kirk's Avatar
capn kirk
Unhappy Please Help PITMAN ARM stuck
anyone have any ideas how to get pitman arm off i've tried heat, prybar hammers, air hammer, tierod/ ball joint forks and i can't get any budge, i've only got butane torch not a ton of heat,
i need ideas really bad thanks for any help.
Old Apr 7, 2007 | 06:53 PM
ken75ranger's Avatar
ken75ranger
Go to Autozone and borrow a pitman arm puller.
Old Apr 7, 2007 | 08:53 PM
vloney's Avatar
vloney
If you're not saving the pitman arm, drill 3 or 4 holes in a straight line, then using a chisel or air hammer, chisel along the holes creating a crack. Most of the time, the arm will drop off.
Old Apr 7, 2007 | 09:10 PM
high ho silver's Avatar
high ho silver
Hopefully you have not damaged the steering box with all that hammering.
Old Apr 7, 2007 | 09:19 PM
FortyFords's Avatar
FortyFords
You don't want to overheat any steering component.
Yes ,get a special puller
Rich
Old Apr 7, 2007 | 09:38 PM
capn kirk's Avatar
capn kirk
thanks for the tips i forgot to say i had a puller on it we finally got it with heat on the outside of the arm for a while then using a tie rod end splitter on either side of the stud from the steering box thanks again
2001SuperDuty
Jan 31, 2019 01:12 AM
77_f250_custom
Jan 25, 2015 07:58 PM
fordcrzymike
Nov 8, 2014 09:01 AM
MIKEDENGINEER
May 9, 2014 07:50 PM
52' fordnut
Mar 6, 2014 12:18 PM
