Bronco II Ford Bronco II
84 BII Codes
Old Apr 7, 2007 | 05:14 PM
Maddognv's Avatar
Maddognv
Question 84 BII Codes
Hey Everyone,
I have 84 BII ,2.8 that I bought for $200 bucks a couple of years ago. I did plugs, cap, rotor, wires, o2 sensor, fuel filter and adjusted the valves.I also cleaned the EGR valve and it looked in pretty good shape. It failed on the idle portion on the smog check. It has a slight miss at idle and and a small amount ot white smoke and moisture coming out the tailpipe. The codes came up as:
KOEO- 31,54,
KOER- 23,24,31,33,34,
It runs great on the road and the gas mileage doesn't seam that bad. I don't want to dump a bunch of $$$ into it. Body's in good shape,a few small dents and no rust. Plus it's a lot more fun to drive than my 83 ranger. Any thoughts?
Thanks,
Maddog (woof,woof)
Old Apr 7, 2007 | 10:36 PM
kernel-panic's Avatar
kernel-panic
31: EVP - (O, R, M) EVP signal is/was out of range - EVP
EVR - (O, R, M) EVP signal is/was low - EVR
PFE - (O, R, M) PFE signal is/was low - PFE
54: Intake Air Temperature (IAT) or Vane Air Temperature (VAT) signal high
- IAT/VAT
23: Throttle sensor out of range or throttle set too high - TPS
24: Intake Air Temperature (IAT) or Vane Air Temperature (VAT) sensor out of range
- IAT VAT
33: ALL - (O, M) EGR did not open/ respond during test or if memory code, did not
open intermittently - EVP EVR PFE
34: EVP - (R) EGR did not respond properly during test - EVP
EVR - (O, R, M) EVP sensor is/was high - EVR
PFE - (O, R, M) PFE sensor is/was out of range - PFE
http://www.therangerstation.com/tech...igitcodes.html
Is the 'white smoke' like steam? Heavy white smoke is an indicator of the head gasket(s) being blown (as also noted by creamy junk on your oil dipstic, as well as in the radiator...). Something a little more like steam, especially in cooler temperatures is just the hot exhaust reacting with the outside air, and you'll always get some moisture out of the tailpipe (catalytic converters convert a percentage of the carbon monoxide to water, if memory serves me correctly...).
srqdiesel chef
May 7, 2014 08:35 PM
rowdyredneck
13
Feb 16, 2014 11:50 AM
brunomisty
Modular V10 (6.8l)
Jul 5, 2012 08:30 AM
xgatorx1976
43
Apr 29, 2008 09:54 AM
zomby woof
1997 - 2003 F150
Sep 5, 2006 10:34 PM
