First Post---Broken Truck
Old Apr 7, 2007 | 05:06 PM
scottriddl's Avatar
scottriddl
I have been reading these forums for about a month and now finally have a reason to post . I recently purchased a early 99 F350 PS 4x4 CC with a 6 speed manual and was very happy until now. Last night i drove her home and parked it . Ran fine no problems . This morning I plugged her in for about 2 hours since it was below 30 and went to crank her and she turned over fine but wouldnt start .
One thing i did notice is I dont get a WTS light but thought maybe since it was nice and warm under the hood the Glow plug relay didnt need to be on . I used a screwdriver to jump the glow plugs just to be sure but it still wouldnt start .
I then replaced the CPS thinking that may be the most obvious thing but that didnt work either .
I did check the fuel bowl and it has fuel in it so im not sure if its a fuel issue or not .
I hate my first post is begging for help , but I know its the best place to ask for help . Any ideas on what to check next ?
Scott
Old Apr 7, 2007 | 05:16 PM
Uzumati's Avatar
Uzumati
If the WTS light is not coming on the fuel bowl heater has probably shorted and blown fuse 30. It also powers the PCM. The WTS is not tied to the glow plugs it is simply a self check light that should come on everytime the key is turned.
Old Apr 7, 2007 | 06:16 PM
scottriddl's Avatar
scottriddl
thanks for the quick reply . One thing though , I dont have a fuse 30 under the hood . according to my manual 30 is a relay ? And if it is this fuel heater , where is the connector i need to unplug ?
Scott
Old Apr 7, 2007 | 06:22 PM
Uzumati's Avatar
Uzumati
The fuel bowl heater/water in fuel sensor plug is on the rear of the fuel filter housing next to the drain valve. unplug it before swapping the fuse and leave it unplugged until you can fix it.
30 under the dash.
Old Apr 7, 2007 | 06:40 PM
scottriddl's Avatar
scottriddl
Thanks a ton!!!! I unplugged the heater ( noticed some burnt area on it ) , replaced the fuse and she fired right up!
Scott
Old Apr 7, 2007 | 06:45 PM
Uzumati's Avatar
Uzumati
Good to hear
The bowl heater is just over 100 bucks available from www.powerstrokeshop.com
Part Number: F81Z-9J294-AA
Old Apr 7, 2007 | 07:34 PM
DavidT.'s Avatar
DavidT.
Alan, gave you some props. Great accurate information!
Old Apr 7, 2007 | 07:46 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
I agree. Rep points to Alan. That was impressive.
Thagodeus
Jun 29, 2014 07:52 PM
Thagodeus
Jun 26, 2014 08:43 PM
MrsCopenhagen
23
Dec 9, 2013 05:25 PM
mozzles
Oct 28, 2012 07:49 PM
IDPisan
17
Jan 23, 2008 09:42 PM
