Brain teasers.
Old Apr 8, 2007 | 11:44 AM
  #31
Bruker's Avatar
Bruker
C'mon, tell us the answer...
Old Apr 8, 2007 | 12:14 PM
  #32
cepurvis's Avatar
cepurvis
Chamber pressure of a .270 Winchester is higher than that.
Old Apr 8, 2007 | 12:24 PM
  #33
tewferford's Avatar
tewferford
Thats the pressure in my brain, waiting for the damn answer.
Old Apr 8, 2007 | 12:48 PM
  #34
furball69's Avatar
furball69
The pressure between my foot and the gas pedal when I'm PO'd.
Old Apr 8, 2007 | 12:55 PM
  #35
924x2150's Avatar
924x2150
I'll goe with the high heels theory..one person joked about Rosie O'donnel, Answer ;The pressure on the heel tip when Rosie is running away from Don Trump.
Edit /I just researched..only about 1600psi on a high heel..
Old Apr 8, 2007 | 01:27 PM
  #36
Keepin It Real's Avatar
Keepin It Real
If you drop an aircraft carrier from a height of one mile above the earth onto the cranium of an unsuspecting bystander, it will impact with a force exceeding 51,000 psi.
Old Apr 8, 2007 | 03:12 PM
  #37
Mil1ion's Avatar
Mil1ion
Originally Posted by Admin
It is not a gun, nor nuke nor.....jaws...one was headed in the correct direction but did not carry it through
Okay, IIRC, this is the pressure on a whale's body at the depth of about 900 ft .....and a certain kind of Whale (probably a sperm or killer whale) can dive down to...about 3000 ft.
Old Apr 8, 2007 | 04:41 PM
  #38
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Nope...nothing to do with a whale
Old Apr 8, 2007 | 04:58 PM
  #39
Mil1ion's Avatar
Mil1ion
Well then, does it have to do with water (ie: ocean) ?
It has to be an engineering thing.
Perhaps drilling in the ocean ?
Old Apr 8, 2007 | 05:02 PM
  #40
nubeee1's Avatar
nubeee1
Originally Posted by Code3
The San Andreas Fault, between the techtonic plates?
Its the fault.....Somehting to do with the fault?? Is it my fault????
Old Apr 8, 2007 | 06:14 PM
  #41
Kep4's Avatar
Kep4
Jäger
A hammer hitting the head of a nail.
Old Apr 8, 2007 | 06:56 PM
  #42
SPL Tech's Avatar
SPL Tech
The pressure found at the inner core of the earth? The pressure a large volcano explodes with? The amount of pressure my system is capable or producing?
Old Apr 8, 2007 | 07:07 PM
  #43
Keepin It Real
C'mon, fellas, you know it has to be something odd,offbeat,simple, stupid or silly. All this engineering stuff is too obvious. It's like "What's yellow and black and lays on it's side in the ditch?"
Old Apr 8, 2007 | 07:29 PM
  #44
Mil1ion's Avatar
Mil1ion
Some people didn't read the exact wording in the question.
The answer is a: Location on the planet Earth
Old Apr 8, 2007 | 07:36 PM
  #45
thorseshoeing's Avatar
thorseshoeing
decadent and depraved
Someone almost had it earlier. (I actually do know the answer, I'm just not telling.)
Tim
