Sponsored by: Real Truck
Need Help With Leveling Kit
Old Apr 11, 2007 | 05:45 PM
nut1605's Avatar
nut1605
Smile
Ok, so I have done some looking around. I have found a Donahoe Racing 2.5" Leveling System from Truck Toyz. Here is the link to it:
http://www.donahoeracing.com/prod_de...l=Super%20Duty
Does this kit come with everything I will need to do the job the right way the first time? Are there any extra parts/accessories I will need to get to make sure no damage is done to my truck? Will this kit make my truck sit perfectly level (at least NOT nose high?) Sorry for all the ignorant questions, this is the first suspension upgrade I have ever done on a truck, and don't want to hurt my baby! Thanks!
Old Apr 12, 2007 | 09:16 AM
Overkill's Avatar
Overkill
FTE *******
The DR 2.5" system includes everything you will need to level your F350. For F250s we recommend adding 4" rear blocks to achieve the same level stance. Though the parking area slopes down towards the rear a bit here is an example:
Old Apr 12, 2007 | 10:00 AM
levi'sford's Avatar
levi'sford
Is the Danahue system the best. How much is the system? I want to do this right, rather than cheap and fix it later. Looks good, Levi
Old Apr 12, 2007 | 10:37 AM
nut1605's Avatar
nut1605
Thanks for the pic, it helps me visualize what my truck would look like. The only part that worries me is that it still looks nose high. You said the parking lot slopes, but there looks to be a bigger gap between the tires and the front wheel wells than the rear wheel wells. Anybody else with any other pics? Thanks!
Old Apr 12, 2007 | 10:39 AM
Overkill's Avatar
Overkill
FTE *******
IMO, the DR system is the best available. Feel free to shoot me an email for pricing. http://www.trucktoyzperformance.com/contact/
Old Apr 12, 2007 | 11:10 AM
saltamontes's Avatar
saltamontes
try the gallery, there are lots of pics of leveled trucks.
www.TruckToyzPerformance.com has a gallery as well w/ lots o' good pics
.. now if somebody would just build a 4" duel-rate coilover w/ fox shocks..
Old Apr 12, 2007 | 11:21 AM
sgthawkusmc's Avatar
sgthawkusmc
Originally Posted by Overkill
As a radius arm suspension system rotates around a central pivot point, additional lift without installations of alignment cams will result in loss of castor which will affect stability and cause wandering especially when loaded. Also, extending the factory shocks 2.5" virtually eliminates droop (the ability for the suspension to extend) which limits the wheels ability to follow the terrain and translates into a choppy ride. Alignment cams puts the truck back to factory spec and replacement coils with the proper aftermarket shocks can increase suspension travel and improve ride quality and performance.
I don't doubt that to the letter of design/engineering you're absolutely correct. The shocks I won't debate, but do you really think the 2.5" is going to make a significant difference to caster? I don't get any wandering issues resulting from loss of castor. Neither does anyone else I know with the leveling kits. I'd also be curious to know if the alignment specs are different for Diesels and gas powered rigs?
Old Apr 12, 2007 | 11:25 AM
RagingBull2k2's Avatar
RagingBull2k2
I'm getting a wander with the stock springs, not to mention it doesnt return to center... I've heard correcting the castor would get rid of the wander... if anything, I think the truck wont wander anymore with the lift springs, but we'll see... still looking for pics of trucks with 37's and 2" of lift w/ glass..... hmmmm....
Joey
Old Apr 12, 2007 | 02:18 PM
Overkill's Avatar
Overkill
FTE *******
A stock ‘05+ Superduty 4wd has roughly 3 degrees of castor. Increasing ride height by 2.5" takes that down very near 0 (and negative when loaded). Castor is what give the truck’s steering the mechanical leverage to track in a straight line and return to center (Same principal as the front wheels on a shopping cart). With 0 castor the steering no longer has a mechanical advantage over the ground so the truck will have much greater tendency to follow undulations in the road. The DR system includes 2.5 degree castor adjusters to correct for the loss of castor due to the additional lift.
Alignment specs for gas and diesel are the same +/- 1 degree.
Old Apr 12, 2007 | 02:24 PM
sgthawkusmc
Interesting. I might have to check it out now. Thanks for the lesson.
Gear619
Jul 14, 2016 08:56 AM
Brown Falcon
May 25, 2016 10:13 PM
crazyduck
6.7L Power Stroke Diesel
13
Oct 3, 2013 09:03 AM
FallstonYJ
Apr 30, 2012 09:22 PM
cdavis850
2004 - 2008 F150
Nov 21, 2010 06:50 PM
