Sponsored by: Auxito
Broken Leaf Spring
Old Apr 7, 2007 | 11:34 AM
93RangerXL4x2's Avatar
93RangerXL4x2
Broken Leaf Spring
crappy, I was hauling a load of wood at my farm, and had a trailer load 2 and a leaf poped out on the passenger side didint make mucdh difference but theres a rattle now and its anoying, how do I put the plate back in, its onely one,
Old Apr 7, 2007 | 09:59 PM
Ultramagdan's Avatar
Ultramagdan
Let's see what others say.
Old Apr 8, 2007 | 03:08 AM
93RangerXL4x2
yeah I want it fixed or I cant load my box up to 1700 pounds, or shoud avoid it.
Old Apr 8, 2007 | 08:29 AM
grafekie's Avatar
grafekie
You doing it with that 98 XL? You can't haul that much anyways, even if it wasn't broken, silly. As you can tell, since it snapped. 1700lbs in the bed, PLUS the trailer, you are slightly over your limits there! You could add air suspension or an add-a-leaf system to bump your payload up, but as I found with my 7000lbs gooseneck, even if the suspension and the axle can handle the weight, watch those tires!
Old Apr 8, 2007 | 10:02 AM
Beast12's Avatar
Beast12
Here is my take on it:
First that is probably too much weight for the truck BUT it is your truck so do what you want. I would fix it one of two ways.
1) I would replace the broken leaf spring and then add one or two more to help handle the weight a bit more. Also add one or two to the other side as well.
or
2) Replace the broken leaf spring and add a set of Timbren's in the back. I just installed a set of these in the rear of my Dad's truck this past week. Seems to help a bit and can easily be installed in under an hour.
They are a bit costly at around $200 for the rear set. But, VERY easy to install. When unloaded it will not affect ride quality. Here's their website: http://timbren.com/
-Matt
Old Apr 8, 2007 | 10:13 AM
93RangerXL4x2
it handles 1700 easily, engine is amazing, i get it fixed.
Old Apr 8, 2007 | 12:15 PM
grafekie's Avatar
grafekie
you do tat, it done good, it do good next time to. it broke good cuz you treat it nice.
Old Apr 8, 2007 | 12:31 PM
93RangerXL4x2
yeah its a ford, I treat it like a royal scrap hauler. lol
Old Apr 8, 2007 | 12:58 PM
alberta46's Avatar
alberta46
Just a note there is a recall on the rear leaf springs you might get it fixed for free. Check the recall section on this forum.
Old Apr 8, 2007 | 01:32 PM
grafekie's Avatar
grafekie
I'm sure the "well I was hauling 1000lbs more than its rated for" will kinda negate any recall notice.
Old Apr 8, 2007 | 01:33 PM
93RangerXL4x2
my trucks rated for 1600, whats wrong with a few 100 more.
Old Apr 8, 2007 | 03:56 PM
grafekie's Avatar
grafekie
Well, you tend to break springs....
You said 1700 plus a trailer... add on 10% of the trailer's weight too. If that's a 5000lbs trailer, you had 2300lbs on those leaf springs, well over their capacity.
Old Apr 8, 2007 | 06:30 PM
93RangerXL4x2
yeah thats very true, but its all good. just gotta fix it/ get a new one better one. my trucks rated for 1600, im sure, Im gonan get them fixed and do the same.
GuitarJesus
Feb 27, 2015 04:07 PM
Supercab
All Things Towing
Oct 10, 2011 12:37 PM
wilbur996
Apr 4, 2010 10:00 AM
DonMurray
1983 - 2012 Ranger & B-Series
Oct 23, 2009 05:04 PM
billygoat
Mar 11, 2008 10:34 AM
