Electrical issues
Old Apr 6, 2007 | 09:46 PM
Stoogefan's Avatar
Stoogefan
Electrical issues
Evening everyone. I'm having issues with my truck (`85 F150 XLT Lariat reg. cab, carburated 351W auto). I've recently replaced a puked battery, and now my truck seems to be running strictly off of the battery and not the alternater.
I had the alt. checked and was told it was fine. I traced all of the wires running from the alt to the battery, the battery to the starter, etc and everything seems fine. Started relay seems fine as well.
The truck starts fine, until it runs the battery down ... then it's back to the charger in my basement.
Anything that I might be missing ??
Thanks .... Jeff
Old Apr 6, 2007 | 10:16 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Have you checked for a blown fusible link? If it is open you will not charge the battery. Check for power at the back of the alternator with the engine not running. If there is no power, then you fusible link is open.
Old Apr 7, 2007 | 10:31 AM
Franklin2's Avatar
Franklin2
A fusible link is a colored rubber thing in the wire. It should have one in the large wire going from the alt to the large post on the starter solenoid.
Old Apr 7, 2007 | 12:19 PM
Stoogefan's Avatar
Stoogefan
Thanks for the help guys. Turned out that the voltage regulator had puked right along with the battery. Got the new one put on, and all is well.
Again, thanks .... Jeff
Old Apr 7, 2007 | 12:33 PM
82F1507.5's Avatar
82F1507.5
I was about to suggest the voltage regulator as that is the leading cause for a puked battery. If the voltage regulator contacts stick closed, the alternator overcharges the battery causing it to boil and in some cases catch fire, and in the rare instance, explode. Lucky you got the cause of the problem resolved. Good job!
Old Apr 7, 2007 | 04:01 PM
Mil1ion's Avatar
Mil1ion
Batteries these days are just as apt to be bad right off the shelf as any other electrical part.
They sulfate,develop a short inside themselves right from the get go.
They don't make them like they used to.....because they want to sell more of them
Old Apr 7, 2007 | 04:14 PM
82F1507.5's Avatar
82F1507.5
Yup!
Is a new battery really a new battery or a recycled old battery in a new case? Once the cells are removed from an old battery and cleaned, if there is enough remaining metal, guess what??? It becomes a new store brand battery with a 24/36 month warranty.
In the good old days all car batteries were sold off the shelf dry. An electrolyte package came separate with the battery and the battery had to be charged before use. Can anyone think of a reason why the batteries were sold like that?
Old Apr 7, 2007 | 10:25 PM
Stoogefan's Avatar
Stoogefan
Originally Posted by 82F1507.5
Yup!
I was a little surprised myself when I went to pick up my "new" battery last week. My wife dropped me at the front door, and I said I'll just be a couple minutes .... thinking the exact same thing. Add the electrolyte, and away I go. Welp, the kid pulls the battery off the shelf, goes directly to the charger with it, and tells me to come back in 25 minutes. Times have sure changed over the past few years ....
Jeff
Old Apr 8, 2007 | 12:10 AM
Mil1ion's Avatar
Mil1ion
In the 50's and 60's batteries lasted 12-15 years.
I took a tour through a Battery Plant when I was in 2nd year H/S automotives in 1967
Quite impressive and the quality was un-matched at that time.
auriferous
6.4L Power Stroke Diesel
Dec 25, 2013 10:57 PM
Jeff K
Oct 7, 2013 08:03 PM
mattcad
40
Jul 17, 2013 11:02 AM
tommyzr800
1997 - 2003 F150
15
Mar 5, 2012 08:09 AM
BCHauler
19
Apr 21, 2010 02:36 PM
