smog pump?????
Old Apr 6, 2007 | 06:19 PM
rustyolred27's Avatar
rustyolred27
smog pump?????
1996 f-250 4x4. 5.8 v-8. smog pump is locked up. does anyone know what belt to get if trying to bypass the smog pump? i do not have to have a sniff test here.
Old Apr 6, 2007 | 06:35 PM
Bruce R Leech's Avatar
Bruce R Leech
cut your old one and use it to measure how long you need then take it to the part store. I keep an old long in my tool truck to use when on rode calls.
but you are going to need to disconnect and block off every thing that connects to it. not a small job. it might be easier to just replace the pump. tour truck loses a lot of resale value with it gone. and we will all breath easier.
Old Apr 6, 2007 | 07:18 PM
flareside_thunder's Avatar
flareside_thunder
As for removing the belt?Why wouldyou cut it when you could just loosen the tensioner pulley.As for the smog pump..he's right you MUST plug everything, however, check your belt routing as my 5.0 1995 I cannot bypass the pump with the shorter belt, I have to get a pump delete kit (in the plans).And the breathing....uh don't get me started...I'mremoving mypump and getting help with it from a buddy who's done it twice.....
Old Apr 6, 2007 | 07:46 PM
Bruce R Leech
read the post
Old Apr 6, 2007 | 08:20 PM
mikeyswood's Avatar
mikeyswood
Originally Posted by Bruce R Leech
read the post
Most parts stores and hardware stores have belt measurers. If you don't cut it you can simply double the length of the belt stretched out. Also, as long as you do not cut it, it can be used as a back-up.
I would replace the pump for now. PM me if you need an old one. I plan to get a compressor in place of the smog pump so that I can run an air tank on my truck and keep the same belt routing.
Bonus------I will get the big truck "pshhtttttt" when the pressure gets to high. I can't wait!
Mike
Old Apr 28, 2007 | 01:59 PM
'88_F-150's Avatar
'88_F-150
just to let you know that sound is the air drier purging not a high pressure relief valve.
Old Apr 28, 2007 | 05:56 PM
XR400's Avatar
XR400
You don't have to plug anything, & you don't have to take anything off. I used a flexible steel tape to get the length I would need on a 5.8 minus the smog pump. OEM belt including smog pump was 102", bypassing pump belt length was 94.5". I put it on without removing anything including the pump. Caused no problems, no codes set, no interference, no drivability issues (as long as one-way check valves & cross-over pipe are still sound).
Old Apr 28, 2007 | 06:49 PM
DJdemon6696's Avatar
DJdemon6696
for flareside thunder
haha no problem about the tag man.. hahaha lets just say its a slogen against those ricers ! lol
