Third tail light
Old Apr 6, 2007 | 04:40 PM
Phil86's Avatar
Phil86
Third tail light
This should be soo simple, but for whatever reason, I can't get my third tail light cover off to replace the brake light bulb. '95 F-150. After unscrewing the two screws, the assembly only pulls out about an inch, if that. What's the secret to getting it out further to be able to replace these bulbs?? Thanks!
Old Apr 6, 2007 | 04:47 PM
quicklook2's Avatar
quicklook2
the whole assembly pulls away, not just the red lense.
Old Apr 6, 2007 | 05:20 PM
Phil86's Avatar
Phil86
I know this, but I'm wondering how the assembly pulls out, after taking out the screws.
Old Apr 6, 2007 | 06:54 PM
92F150Flare's Avatar
92F150Flare
Could be the wire is kinked and holding it in? My passenger taillight was that way, I had to work it back and forth and then barely had enough room to reach behind and twist the socket.....after it twisted a 1/4 turn the lens part came right off.....
Good Luck
Old Apr 6, 2007 | 10:18 PM
bradplock's Avatar
bradplock
i have found that folks like to replace the bulbs with higher wattage ones. this melts the plastic on the bottom of the assembly and gets in the way when trying to remove it. i think this what's wrong with yours, you're going to have to figure out a way to squeeze the assembly out past the melted plastic...
Old Apr 7, 2007 | 10:42 AM
Phil86's Avatar
Phil86
Hmm, yeah that could be the problem then. Thanks for the advice, I may just end up taking a dremmel to it and buying a whole new assembly...
Old Apr 7, 2007 | 11:20 AM
quicklook2's Avatar
quicklook2
this is not that hard a job.
it may help to take ou the inside light cover, than you can see if something is melted on the outside light.
Old Apr 8, 2007 | 03:54 PM
F150Fiend's Avatar
F150Fiend
Maybe this'll help
Ihave a '94 that gave me the same problem. Turns out, after a LOT of grief, the bubls had melted the bottom of the plastic insert and it was hanging up while I tried to pull it out! Almost made me fail a safety inspection. Just had to wiggle and play with it. Hope this helps.
Old Apr 8, 2007 | 07:25 PM
bradplock's Avatar
bradplock
F150 fiend, that is what i am talking about. the bulbs melt the plastic on the bottom. it happened to my Bronco and guess what? This same forum helped me figure it out. I love this place!!!
Old Apr 9, 2007 | 08:22 PM
jonathandennell's Avatar
jonathandennell
I broke mine while taking it off..
Anyone know of a place to buy a new one?
(Mine melted and caused it to weaken and stay in there..)
Old Apr 10, 2007 | 04:24 PM
bradplock's Avatar
bradplock
LMC truck or Ebay is where i would start...
