Steering question
Old Apr 6, 2007 | 11:33 AM
1ole4d's Avatar
1ole4d
Steering question
How hard would it be to convert a manual steer to power steering in a '66? I'm looking at purchasing a 1966 car hauler that is in great shape but has manual steering. Personally for something that big power steering or power assist would be a lot easier to handle and maneuver. Any sites I could check out or...?
Old Apr 6, 2007 | 03:58 PM
airharley's Avatar
airharley
Look under the tech article section tab at the top of the web page. There is a article covering what you may be looking for. You can even do a search of this forum to find related topics.
Old Apr 6, 2007 | 06:00 PM
oldtrapper's Avatar
oldtrapper
When I changed over to PS,PB @ TILT WHEEL The swap of the manoual to power was ez. If you use a ps eng perch on the driver's side will enable youi to unbolt your old steering box you rebolt your poser box up using the same 3 long bolts and since you replaced the eng stand witih one that is bent forward and will clear the ps box which is a litte longer without modifying any thng the hood.I used a stand from a 74 which had ps and a 360/390 eng, You will need the brackets and a new pump for a 79
truck w/ps. It will surprise you how ez it is. My old 66 drives fine.
Old Trapper
Old Apr 6, 2007 | 07:14 PM
FordBoypete's Avatar
FordBoypete
Question
What model is the Car Hauler you're looking at and is it a single I Beam front axle with leaf spring suspension or Twin I beams with coils? I 'd need to know that befor I can respond with an answer to your querey on P/S.
FBp
beckman
Apr 17, 2013 11:54 PM
Blackwaterforge
Oct 25, 2012 07:25 AM
carner1982
May 15, 2008 07:00 PM
Jamie V
Jun 2, 2004 11:00 PM
cburwell
Oct 23, 1999 03:46 PM
