getting gauges put in
Old Apr 6, 2007 | 11:19 AM
01redcrew's Avatar
01redcrew
today im getting the 3 pillar gauges put in and im wondering what the gauges should read. I have stock turbo and tran with a valve body put in and i have a 4in stright pipe as exhaust.
Old Apr 6, 2007 | 11:35 AM
Pocket's Avatar
Pocket
Without a chip, peak turbo boost should read between 15-18 lbs. Cruising on flat highway should be below 5 lbs.
Tranny temps should hover 140-160 empty.
Pyro will depend on where you mount the probe, pre-turbo or post-turbo. It's HIGHLY RECOMMENDED to mount pre-turbo in either the exhaust manifold (drill and tap), or the up-pipe (clamp method). Pre turbo temps for a stock truck with a 4" pipe should easily stay below 1200 degrees at WOT. Normal cruising speeds on the highway should hover around 600.
Old Apr 6, 2007 | 11:50 AM
01redcrew's Avatar
01redcrew
thank you very much thats all i needed for now
Old Apr 6, 2007 | 02:08 PM
CSIPSD's Avatar
CSIPSD
Install them yourself... Save the $150 there going to charge you...
Gmangh15
Nov 16, 2011 09:11 AM
kuch73
Oct 20, 2011 01:10 PM
housedad
Jul 20, 2010 07:03 AM
Sparkplugless
May 29, 2009 01:31 AM
Pocono Super Duty
Mar 3, 2007 07:58 PM
