Amp Gauge question...
Old Oct 20, 2011 | 08:42 AM
kuch73's Avatar
kuch73
I have the full gauge cluster in my 77 and the charge/discharge gauge never seems to move. How can I tell if it is working correctly. all the other gauges work fine. I thought if I put a draw on the battery, such as lights on, without the engine running, the gauge should show a neg charge, but I get nothing. Could it just be the gauge bad, or a wiring problem somewhere? Thanks
Old Oct 20, 2011 | 08:47 AM
fmc400's Avatar
fmc400
MSEE
Honestly, this behavior is normal. That's how they all work. They're pretty useless. You would exect to see a slight deflection with the engine off and lights on, but as wiring ages and resistances increase slightly, you may not see it.
An aftermarket voltmeter is a much more useful indicator of your charging system's behavior, if you're interested in going that route. An ammeter isn't entirely useful because it only gives relative measurements.
Old Oct 20, 2011 | 01:10 PM
montana_highboy's Avatar
montana_highboy
Like FMC said, it's "normal" for this particular gauge to have virtually no movement, Ford issued a TSB on this many moons ago...
Ford Ammeter Gauges: Do They Work? | MILEPOSTS Garage (Tech Tips)
CelticOne
Ford Truck Parts for Sale
Feb 1, 2017 10:30 AM
cb4492
Electrical Systems/Wiring
May 13, 2004 09:58 AM
lshort
Mar 27, 2002 12:56 PM
n3ffn
Mar 10, 2001 09:54 PM
