1978 - 1996 Big Bronco
Bronco Help Please
Old Feb 13, 2002 | 12:33 AM
EddieBronco's Avatar
EddieBronco
Bronco Help Please
Well first of all i have a 89 eddie bauer bronco with a 302 EFI, that has had a tune upon 2/11/01, and a new 3" exaust the same day, well i have a few questions, for starters, my thermostat on the insturument panel does not work, it will only go up a very little bit and no matter how hot it gets it will stay in the same place, and if i drive the bronco around enough like today and i turn it off, it will have a mean time starting up, and when it does i usually can drive it a couple of feet with big clunking noises if i try to push hard on the gas, and once i can cruise for a little while maybe a couple of feet, it will run alright again, i wanted to know why this happens, and if the reason could be the thermostat, it has a new exaust on it, a brand new alternator, and a brand new water pump.
Thanks for reading hope to hear back
Joey
BigGreen
Old Feb 13, 2002 | 04:00 AM
SBV1's Avatar
SBV1
Bronco Help Please
A few questions first.
Did it do the symptoms before the tuneup?
Did you have someone (shop) do the tuneup?
What was done on the tuneup?
What do your computer codes read?
As far as the temp gauge goes, did it start doing this after the tuneup? Does your oil pressure and gas gauge work ok? Of so, find your temp sensor, take the wire off and run it to the manifold or a good ground, then make sure it isn't touching anything. If the gauge is good it should go full one way or the other.
Old Feb 13, 2002 | 04:06 AM
SBV1's Avatar
SBV1
Bronco Help Please
85bronco85
Mar 10, 2013 06:35 PM
justin25taylor
Aug 14, 2007 12:08 AM
dijera
17
Jul 7, 2005 06:05 AM
RoyalFord
1997 - 2003 F150
16
Nov 3, 2004 10:24 PM
