timing pointer location
Old Apr 12, 2007 | 09:56 AM
armikk's Avatar
armikk
Oh, the shiny spot on the timing cover is the spot that doesn't get painted when the engine is painted quickly and sloppily with the balancer still in place... It is bare steel. When installed, the dampner was not rubbing / touching the timing cover.
Old Apr 16, 2007 | 02:37 PM
armikk's Avatar
armikk
I did a little checking over the weekend. I bolted both timing pointers on the engine, turned the engine over until #1 piston was about at TDC, and re-installed the balancer. The balancer and drivers side pointer were lined within a few degrees of TDC. I turned the crank a few degrees until it was at TDC and painted a mark on the balancer at the passengers side pointer. I've got a timing light with the adjustable advance built in, so I'll use that, the passengers side timing pointer, and my painted mark to set the timing once I get the engine going. Thanks to everyone for the insight and information...
Old Apr 16, 2007 | 03:19 PM
grclark351's Avatar
grclark351
just get a timing tape and stick it on there...
maine71f100
Apr 28, 2017 05:34 PM
marcogyver
Mar 11, 2014 07:32 PM
Gregory Glaser
Sep 2, 2012 08:38 PM
78Ranger400
Apr 21, 2011 04:22 PM
78Ranger400
Nov 5, 2010 06:22 PM
