Tranny problems...great...
Old Apr 6, 2007 | 07:25 PM
fellro86's Avatar
fellro86
I would go with the tranny filter change. C6's are easy, as stated, you take the pan off, so it's messy, but not hard. The filter is held on with bolts, so it isn't too bad to deal with. The ones that are a pain are the push in style. The rear pan bolts may be tricky to get to, loosen the trans mount bolts and jack up the trans, then they are easy. It doesn't sound serious, could just be some gunk holding the shift valves, modulator valve, or the governor valve. You also will know more when you pull the pan. The color of the oil and the amount of sediment on the bottom of the pan tell a lot. Sediment is normal, chunks are not. If it is so thick it looks like mud, that is bad though.
Old Apr 6, 2007 | 07:40 PM
Jake S's Avatar
Jake S
Have you checked how much vacuum you have? Because if the shifting is weird and the brakes are funny too, sounds like a bad vacuum pump to me... should be about 20 inches of vacuum and climb there fairly fast. If it doesn't, then there might be a leak somewhere or a bad pump. Hope it helps
Old Apr 7, 2007 | 08:50 AM
F350_Hauler's Avatar
F350_Hauler
Originally Posted by Agemenon
As far as the brakes go, they have a mind of their own. Most of the time I have to push the pedal in about 3-4 inches for it to start stopping the truck. It stops fine, it's just I feel that I shouldn't have to push in the brake pedal that far to get some stopping power. Anyways, when it does have a mind of its own, the pedal will become stiff and I don't have to really push much on it to get any stopping power, but this seldomly happens. I'm not saying it happens rarely, and it doesn't happen often, it's kind of in between.
If I were you I would jack up the back of the truck and check the brakes. There should be a little bit of drag from drum to shoes. You can hear the contact of the shoes on the drum but there is very little drag. Use a brake spoon or a screwdriver to adjust the brakes through the slot until there is a little bit of drag. You will notice a big difference at the pedal and it will stop nice and straight as long as the fronts are working good.
Old Apr 7, 2007 | 09:03 AM
fellro86's Avatar
fellro86
When the vacuum is low, the trans would shift late and hard, doesn't really sound like that is the case.
Old Apr 7, 2007 | 06:57 PM
Agemenon's Avatar
Agemenon
Ok well everybody's saying all these different things, I just wanna try and narrow it down a bit. Some say its the vacuum, some say its not, some say its the filter and it goes on and on? So what do you think I should do? Change the filter, test the vacuum and change the fluid?
The tranny shifts late, but it doesnt shift hard....so I dunno what to think. What happens if i were to drain the tranny fluid and it comes out muddy lookin? What do you suppose that could mean? I dunno this whole thing is messed and i dunno what to think :s.
Old Apr 8, 2007 | 07:38 AM
mistakenID's Avatar
mistakenID
No one has made a positive ID of the problem. There are ideas of what to check and what to look for.
There are a few fairly simple things that could make your trans have the trouble it's having and those are what have been suggested.
As old as these trucks are, it would not be a bad idea to do most if not all of what has been suggested.
Old Apr 8, 2007 | 10:23 AM
PLC7.3's Avatar
PLC7.3
Check out these guys......
SUPERIOR AUTOMATIC TRANSMISSION REBUILDERS LTD
12547 125 St NW
Edmonton, AB T5L 0T4
(780) 454-2987
They are very good at what they do, are personal friends and 30 year BBB members.
Old Apr 9, 2007 | 02:30 AM
Agemenon's Avatar
Agemenon
alright thanks PLC
PunkysPapa
37
Feb 6, 2011 09:45 AM
BrandyB
1978 - 1996 Big Bronco
Jan 2, 2008 08:23 AM
Mtthwvn73
Jul 31, 2007 04:33 PM
bsmotorsports
32
Jan 14, 2006 07:07 PM
Xdrive
1983 - 2012 Ranger & B-Series
15
Jul 5, 2004 01:14 PM
