Im startring to get dissapointed....
NO mechanics know how to fix this, and ive spent bucket loads of money replacing everything and having throttle bodies cleaned, seafoam, fuel injection flush, system pressures, codes, cap, rotor, plugs, fuel filter, and all to no avail. One even replaced the tranny sensor saying it could be that b/c it controls shift points and fuel adjustments. Another 400 down the drain. It did make my tranny shift smoother, but didnt fix the poor drivability!!
Well, heres the first problem. This first one dose not happen all the time, just every now and then, and it matters NOT how long the truck sits. Sometimes when I start the truck up, most of the time the motor will turn over and run good. But half the time, it will start, and then drop off like its dead, but will somehow cycle itself over again seconds later and start running. Weird. So the truck will idle good and rev up, but its just missing something. You can hear it in how the truck runs, the exhuast note is VERY different, kinda like a 6cyl, almost sounds like the truck is missing, but its running great.
And heres the other weird thing, once I wait until the truck has been driven awhile, (usually by about 20 minutes of driving, sometimes it takes almost an hour) the truck will do a 100 percent turn around and it will run great and the exhuast note will totally change back too the deep v8 grumble and the truck will start to haul *** again. When its not running right, it will still go, but its SOOO slow, and instead of the nice v8 motor revving up noise, I get a loud "whooshing" rev up noise from the motor, and I cant hear the actual motor rev up when its running like that, just like alot of air, like the fan turning hard. Every mechanic tells me that it goes great but makes alot of noise, and thats just how it is. But then I can leave and drive it home, and most of the time on the way home, it starts running right again. I have a flowmaster 40 series on it, so believe me, when its not running right, it sounds like a 1985 chevrolet, like loud crap. But when the truck runs good, sounds like a nice 302 with flows. I cant take driving this truck and half the time its a slow turd with no power, and the other times it runs like a bat out of hell. What the hell is this truck doing???
Everyone thinks im nuts except for my friends and family b/c theyve heard and seen it. Mechanics just dont want to spend the time with it to see how well it SHOULD run. Any thoughts about it?????.....BTW, its a brand new motor, only 12,000 miles on it. 302 5.0 HO.
Thats why I never go to mechanics anymore, or atleast avoid them at all costs. Most of them will not correctly diagnose a problem, and simply have the owner throw money at it as in "it could be this, it could be that" and never fix it. They do that so they can make money off the parts too. There's almost always a way to dianose a part and find out if it's working and could really be your problem.
my 86 302 did the same thing. gutless wonder one second, and tire burning fool the next. finally plugged solid one day on the interstate. i got off at the next exit, rolled into the ford dealer at the bottom of the ramp, and traded it for the 88 diesel. made out good on it too. bought new for $9,500 cash, drove it for 18 months, and traded it for $11,000 off the price of the $18,000 diesel.
A bad TPS will throw a code - since he said he checked codes and didn't have any - we're assuming there are no codes (hopefully code check was done correctly) and that we're looking for problems that do not throw a code...
Such as the cat, MAP can cause problems w/o a code, etc...
The ECT and ACT sensors will throw codes if there is a malfuction - but is a good place to look given the situation.
Kenny
Thinking about your problem...my wife's 2000 Stang had similar issues. It went in 4 times before I figured out the problem and then they fixed it. It was a sticky Idle Air Bypass valve. Funny thing, it made the woosh sound and the car would fall flat on its face, sometimes it would run, sometimes it wouldn't even start. It was terrible when it was cold, but as soon as it warmed a bit (2 minutes of so), it would run like a champ. You could feel it as soon as it released, the engine just felt like it caught a breath.
Kenny
