Broken Glow Plug, Help
Old Apr 5, 2007 | 12:49 AM
redrocket076's Avatar
redrocket076
When I was removing the glow plugs on the drivers side of my 97 F250, the plug at the rear of the engine broke. The exterior shaft broke off and now the plug rod is stuck in place. I have tried numerous things to pull it out with no luck. Any ideas?
Old Apr 5, 2007 | 01:33 AM
preppypyro's Avatar
preppypyro
Just a friendly suggestion, you will probably get better help if you check out the diesel forums! There is tons of good info there, this section is mainly for half tons, with gassers
Old Apr 5, 2007 | 02:05 AM
73f350sc's Avatar
73f350sc
Ya wrong forum....glow plugs are diesel only.
-Chris
Old Apr 5, 2007 | 05:14 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Moved...we will get you an answer....enjoy.
Old Apr 5, 2007 | 09:10 AM
tjbeggs's Avatar
tjbeggs
well its not a good thing that you already know! I had that happen on a customers truck one time and the customer elected to just leave it in there. Its pretty much that or pull the head to get it out. Maybe somebody else has a good tip but if you can't get anything one it to turn, which if it broke really won't matter cause its really stuck, you have no option other than to drill it out and hope you can save it.
Old Apr 6, 2007 | 01:36 AM
73f350sc's Avatar
73f350sc
Well,
Now that we're in the right place....have you tired an easy out on it?
Hope it helps,
-Chris
Old Apr 6, 2007 | 12:07 PM
timberjack's Avatar
timberjack
Whoa, first off before you do anything, is there anything of the broken piece protrouding above the cylinder head?
If there is, there's hope. You need to give it a soak of seafoam, pb blaster, or some thing similar, not much just enough to fill the depression in the cylinder head around where the glowplug seats. Do this once or twice a day for a few days, but at the same time try to get a set of needlenose visegrips to grip the outside piece in case it frees up and sinks in.
After a few days, try twisting with the vise grips, and even at that point try tapping down, not too much, but it may help in breaking the carbon loose, and allow the piece to pull out.
Other's have had good luck after the chemical soak by rethreading the glow plug body back in, and then trying to remove it again. Some have been able to turnout the broken piece with the body after the carbon has been dissolved.
Big thing here is not too rush the job. Keep us posted on the progress, and others will be along soon enough to help.
Ken
Old Apr 6, 2007 | 12:13 PM
timberjack's Avatar
timberjack
redrocket076,
One other thing, there's also a slide hammer type of tool used in conjunction with the visegrips that may help too. Some have found them at harborfreight, i've seen them on ebay, but i imagine if you're handy a simple copy could be made up too.
Here's a large sized one on ebay to give you an idea of the concept.
http://cgi.ebay.com/ebaymotors/New-V...98852444QQrdZ1
mrsvegan
17
Oct 19, 2013 07:26 PM
TJK1
Apr 9, 2012 09:18 PM
bridgeman
Mar 5, 2008 08:38 PM
mick_3399
Oct 30, 2003 09:30 PM
Bold811
Mar 13, 2003 09:52 PM
