1978 - 1996 Big Bronco
Interior Carpet (1984)
Old Feb 16, 2002 | 12:50 AM
jhw8bjw's Avatar
jhw8bjw
Post Interior Carpet (1984)
Hello all,
I have a 1984 Bronco, And from the factory it did not come with neither interior panels nor carpet. The question is, does anyone know where I can Get the COMPLETE (Front to Back) carpet (NEW) for my truck and all the interior panels NEW, and at a VERY affordable price.
By the way I just want to say thanks for all of the help, all of you have given me in the past.
Old Feb 16, 2002 | 12:58 AM
Mil1ion's Avatar
Mil1ion
Try here.
http://headlinerkit.com/ac/ftmc.shtml
Dennis https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
Please Don't Ask Me Any Tough Questions As:
"I'm Saving My Memory For When I Develop Alzheimer's"
78 F-150 429CJ,Silver
w/Explorer Pkge.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old Feb 16, 2002 | 09:25 AM
tamarackstyle's Avatar
tamarackstyle
a couple places to try are:jeffs bronco graveyard-I am ordering a complet new carpet set from them. they carry Auto custom carpets, both vinyl and carpet. you can also get the carpet direct from acc. I went with jeffs because acc wanted more for the shipping than the carpet to get it up here to alaska. As far as panels go Ive seen door panels (new) at jeffs and lmc, but have yet to see the cargo panels. Jeff also carries used stuff so you might want to ask. good luck, Im finding parts for 80's bronco nearly non existant.
Old Feb 16, 2002 | 12:06 PM
restorit's Avatar
restorit
I bought a carpet set from Bronco Graveyard (ACC)..... a good quality set. The only thing I didn't like was having to cut my own holes for the transfer case and tranny floor shifters, but this did help ensure the best fit. As for the cargo panels, consider making your own. My truck originally came with the vinyl floor mat and black, paperboard panels for the cargo area. I bought a sheet of 1/8" masonite from the home improvement center (the same stuff as pegboard, without the holes) and traced the old panels onto it. After cutting them out with a jig saw, I painted them with floor polyurethane to seal them against moisture. From there, I sprayed them with 3M spray adhesive and covered them with bulk automotive carpet, two rolls of which I purchased from WalMart in a color that matched my carpet fairly well.
I got a little creative and bought a 12V power point from the local RV center and installed it in the cargo area, along with two cargo lights and rocker switches (the lights are actually flush-mount marine-type stern lights.) I was very happy with the way these turned out. The pictures aren't of the greatest quality, but I've got a couple posted in my gallery now that show the panels. Maybe this might be a good option for you to consider.
Old Feb 16, 2002 | 03:41 PM
AlM's Avatar
AlM
Nice Bronco! Is that a rollbar?
I need more powerpoints; I have one mounted on top of the driver's side seatbelt retractor housing (next to back seat); and a #12 cable in the cargo area that is used for the back-up alarm; I think I'll add a powerpoint there. Thanks for reminding me.
Old Feb 16, 2002 | 06:17 PM
restorit's Avatar
restorit
AIM:
Thanks! Yes, it's a roll bar I bought from Bronco Graveyard. I believe you could order an optional "GT Bar" on some of the Broncos of the mid '80's. I've seen pictures of it in my Chilton's manuals, and to date I've seen one Bronco with it (believe it was an '84). I don't care for the GT Bar - it's basically got the same hoop that runs from the floor to the ceiling and along the top of the headliner, but the angled supports don't run towards the rear and angle down to the rear wheel wells as on the aftermarket; rather, they angle off a couple of feet up from the floor and attach at a point which is closer forward. Basically, the factory bar doesn't seem as supportive as the aftermarket.
The power points are getting easier to find, I even think you can find them in the automotive section in WalMart. I ended up installing another fuse box under my passenger-side kick panel (running the 8-guage primary wire was a straight shot through the firewall and to the solenoid). From the box, I ran wiring along the passenger side (under the sill plate and behind the cargo panels) to the rear of the truck, which powers my cargo lights (one per side) and my power point. I also purchased a 12V accessory extension cord, which had a female receptacle and a coiled cord. I cut off and tossed the male end, and installed the female with 18" of the coiled cord in the bottom of the console, running wire through the bottom and under the carpet to the auxiliary fuse box. (This is perfect for charging my cell phone.) One of these days I'll have the truck where I want it!
Old Feb 16, 2002 | 06:20 PM
MDB's Avatar
MDB
lance65
60
Oct 23, 2013 05:22 PM
sawgunnerusmc
Oct 22, 2012 09:04 PM
labman1014
Jan 6, 2011 02:24 PM
vtjvt
Mar 11, 2010 06:25 PM
Roc_N_Rev
Dec 22, 2003 07:45 AM
