jobe performance air intake kits
Old Apr 4, 2007 | 11:26 PM
ybarrar's Avatar
ybarrar
has anyone used this system on there trucks? is it louder than the large nappa air cleaner?
Old Apr 5, 2007 | 08:23 AM
ybarrar's Avatar
ybarrar
has anybody out there heared of them?
Old Apr 5, 2007 | 10:33 AM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Its pretty. I would venture a guess that your intake noise would be less due to the diamond plate housing. Looks like there is enough room for the 6637 filter if you didn't like that K&N filter.
Old Apr 5, 2007 | 11:32 AM
heavymetal1's Avatar
heavymetal1
FTE Sponsor
i have a couple of these in stock and went to install one in my truck, 99 f250, it fit but seemed to be poorly made. It has a tube that replaces the plastic coupler with the crank vent tube and it seems to be hokey at best. The air tube that connects to the air filter is straight with no bend so you have to cut your battery cables and lengthen them with supplied ends that move the battery to the back of the box instead of the front like the factory set-up, It does come with a optima battery but it is a 540 cca yellow top. I opted for the Afe stage two instead. These would probably be well suited for the early 99 P/S due to the lack of avalibility of intakes for them as well as the battery is farther back and may not require cutting the cables, not sure though cant bring myself to selling the ones i already have.
Old Apr 5, 2007 | 06:22 PM
ybarrar's Avatar
ybarrar
is there another type of crankcase breather?
fatfenders
Sep 19, 2002 11:21 PM
acogoff
May 6, 2002 04:31 PM
DeGideo
Apr 27, 2002 12:00 PM
fourtrax
Mar 8, 2002 08:56 PM
KevinT
Mar 16, 2001 11:50 PM
