air cleaner
Old Apr 27, 2002 | 05:28 AM
DeGideo's Avatar
DeGideo
air cleaner
Old Apr 27, 2002 | 08:16 AM
shortbedford's Avatar
shortbedford
air cleaner
Help i have been doing a frame off on my 73 f-100 short bed got all the drive train done ive got a 69 460 30 over crane cam edlebrock intake and holley 750. The problem i have is that i installed a davis unified ignition with coil in cap and i cannot get an air cleaner to fit unless it is 10 inches or less in diameter, would that air cleaner be large enough or i was also thinking about installing a 1 inch spacer between the carb and intake but wasnt sure how that would affect the performance any help would be appreciated thanks in advance. "shortbed" chuck
Old Apr 27, 2002 | 12:00 PM
dvlinnell's Avatar
dvlinnell
air cleaner
A one inch spacer between the carb and the manifold, if anything, will improve performance, but not much. Edelbrock also makes a one inch spacer to go between the carb and the air cleaner, this would probly be the easiest and cheapest way to go.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
