Lobe Separation for Speed Density Cams
Old Apr 12, 2024 | 08:43 PM
nitromaster's Avatar
nitromaster
4wd Low
ok, so you're saying i could theoretically run a 110 lobe separation on speed density, but "only" if the durations are around .220 @ .050?
Or would having 110 separation in general be too unstable?
Old Apr 12, 2024 | 10:41 PM
rwfid's Avatar
rwfid
You can always go with an aftermarket ECU if you can't get it to run right on the factory speed density. It might be a little more than you want to spend, but the sky is the limit.
Old Apr 23, 2024 | 07:53 PM
Conanski's Avatar
Conanski
The manifold vacuum signal has to be stock like, in my experience to have any hope of doing that the cam intake duration has to be 210 deg@0.050" lift or less even with 114deg LSA, with 110deg LSA I'd bet it needs to be under 200 degrees.
Old Apr 23, 2024 | 08:37 PM
DaveMcLain's Avatar
DaveMcLain
That's right, for the most part it is the overlap that reduces the manifold vacuum at idle which is what the speed density system doesn't like. The lobe separation controls the overlap along with the duration. If the durations are kept the same for the most part changing the LSA will change the overlap by about 2X the change. So in other words going from 114 down to 110 doesn't change the amount of overlap 4 degrees it changes it 8 degrees which is a lot. The reason I say for the most part is because all lobes are not symmetrical so it can vary a little bit.
The Non HO 5.0 camshaft (the one with the std 302 firing order) checks at 181/195 @ .050 and it is ground on a 108 lobe separation. It has .379 and .395 lift with a 1.6 ratio rocker arm. It has 33 degrees of overlap at .006 cam lift, 19 degrees at .010 and 1.3 degrees at .020.
tsi9973
Apr 14, 2017 09:54 AM
F-250 restorer
Oct 5, 2010 07:24 PM
MCarlson
Mar 19, 2010 01:55 PM
OldRacerGuy
Sep 30, 2008 03:07 PM
nitemandick
19
Apr 7, 2003 11:38 PM
