E40D overhall/servo snap ring and plate missing
Old Apr 4, 2007 | 02:50 PM
blacksheep123's Avatar
blacksheep123
<TABLE><TBODY><TR><TD vAlign=top width="100%">I've got a 95 F350 4x4 powerstroke diesel with a E40D automatic tranny. I'm rebuilding the trans and when I got to the servo the snap ring and the plate below the the snap ring were missing. I'm wondering why the trans still worked good even though they weren't there. The trans shifts fine. Could it be that they put a shift kit in it last time it was rebuilt? How can I tell if it has a shift kit? I'm concerned that if I put a snap ring and plate in it now that it might not shift right once I'm through rebuilding it. Do you discard the snap ring and plate when you put a shift kit in it, or was it just left out?
</TD></TR></TBODY></TABLE>
Old Apr 4, 2007 | 04:13 PM
Cuda_jim's Avatar
Cuda_jim
I though I answered this in the axle forum. Maybe you missed it.
Here it is again:
Are you talking about the intermediate band shift servo, if so some have snap rings and some don't.
NOTE: On some models, the intermediate band servo has a snap ring as a retainer.
Without a snap ring you remove it like this:
Using a plastic or rubber headed hammer, gently tap on the intermediate band servo assembly piston. (The downward force will compress the spring. The upward momentum of the spring will then force the assembly to be released from the case bore.) Remove the servo piston.
LostMayhem
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jan 9, 2008 12:17 AM
Roger Davis
Nov 23, 2007 03:21 PM
bigdog13
Aug 17, 2007 06:55 PM
griz32379
Aug 9, 2007 11:39 PM
MrNuckelhead
Jul 9, 2007 07:39 AM
