Finally got it running again! but.....
My truck has not seen much attention in the last 5 years due mainly to finances and time, My kids are getting older now and it feels great to be able to work on the truck more often. The truck runs smooth. The problem now is a severe leak out the carb, I really cant tell where the gas is coming from appears to be out the top of the bowl, there was quite a bit like a fountain so it was rather difficult to tell.
Oh yea, its a 1957 "272" with a Holley 2 barrel. If you guys have any ideas please let me know, I rebuilt the carb 4 years ago and it has been stored in a box all this time.
None that I know of...maybe some of the old hands around here will be along with some tricks. There is the old "tap on the bowl with a wrench to knock it loose" maneuver, but it's not very elegant...
I just went out to take a peek and with engine off gas is leaking from the accelerator pump on the bottom of carb, it leaks worse when i work the lever. Still sound like a stuck float or gasket issue? Sorry im not real good with carbs.
I'm no carb guru either, I was hoping someone with actual knowledge would jump in and rescue me! I have seen a stuck float basically make fuel come out of EVERYTHING once the fuel pump cranked, so that could still be that issue. You could pretty easily check the accelerator pump diaphragm, if it were bad I suspect it would leak like you're describing as well. I'm not familiar with the details of that Holley, but most have either the screw-in type or the three or four little screws in the cover over it. You could check the diaphragm with minimal teardown in either case. I know some paper diaphragms do not like being left dry. They get brittle and fall apart, even if it's never really been used. Fuel pumps are notorious for that. Work great when you park them, then months or years later when you restart the engine the fuel pump croaks. Don't know if they're the same in accel pumps.
One other thought, and not to insult you, but if you rebuilt the carb and this is the first run, might you have left some "Semi-Important Little Doohickey" (known as a S.I.L.D. in highly technical circles) out during the reassembly?
I really appreciate your guys input, I guess its possible I left something out on the rebuild, but I usually only throw the extra parts away once I'm sure the thing works
On Holley carbs you can adjust the float level without taking the carb apart. Take a look at the float bowl, on the side of it there should be a screw plug, also look on the bowl at where the needle and seat is located, there should be what looks like 2 nuts or a screw with a locking nut.
With the engine running at idle...
What you want to do is to remove the plug in the side of the carb
Loosen the lock nut at the needle and seat and tweak the screw until teh gas level is just below the plug in the side of the bowl.
Tighten it all back up and away you go.
Bobby
Bobby
I may have been a bit hasty. The process I tried to describe is for the later style Holleys that have the larger rectangular bowls that are held onto the carb body with 4 screws, one on each corner.
Bobby
Bobby
Bobby
Bobby
Cool,
Good luck with it. Put a rag or something under the carb to catch the gas. Puddles of gas sitting on the intake manifold can be a bit of a fire hazard if youhave a bad plug wire or the engien backfires (I'd rather not go into details on how I know that....lol)
Bobby
Bobby
The gaskets and seals have probably dried out and shrunk from sitting all that time. You're likely going to have to do a fresh rebuild on it. At least it is still be clean from the last time and you've had the experience so it won't be so bad this time around.
I remember Janet40 from way back on the Y-block forum talking about a Motocraft carb I believe from the 70's that worked on the Y-block manifolds I will have to do some research and see what I can dig up.
