leaking throttle body?
Old Apr 3, 2007 | 04:21 PM
StealthWyvern's Avatar
StealthWyvern
Has anyone had thier throttle body leak colant? I'm currently about to go out and bypass the coolant from running though the throttle body. I'll upload pictures here ina min to better explain. I Just noticed this while replaceing the 3/8ths hose that goes int it which you can see in the below pictures. Now this pipe doesn't leak unless I give it gas! IT leaks where the pipe goes into the bottom of the throttle body.
BTW I have a 94 f150 with 302 ATX in it.
Its leaking at the "pipe" going into the bottom of the throttle body. I have boxed in the area where its leaking at below. This is a side shot from the passenger side.
Here is the view from the front.
Old Apr 3, 2007 | 04:46 PM
quicklook2's Avatar
quicklook2
just bypass it.
Old Apr 3, 2007 | 06:08 PM
StealthWyvern
I did and now my check engine light is on after driving it a few miles! Is thier a sensor in the trottle body?
Is thier a way to properly fix this rather smal issue without havin to replace the throttle body itself?
Old Apr 4, 2007 | 12:23 AM
nighthawk285's Avatar
nighthawk285
if the CEL came on, try and pull codes and see what it says...see http://www.fordfuelinjection.com/?p=13
Old Apr 4, 2007 | 09:39 AM
StealthWyvern
Thanks nighthawk, I was trying to find that last night but had no luck. I belive I have codes 123 and 125 but im not 100% on that. So I stole my gf digital cam and went outside and make a vid clip. I'm currently uploading the clip as I type. This is my first time reading codes like this.
I have included what the ford fuel injection site stated about those two codes. Now when driving the truck it doesn't want to shift. Unless I get it wound up then let my foot off the gas and then back on it lightly.
Code 123
TP circuit above maximum 4.5 volts.
TPS circuit has intermittently failed above maximum 4.5 volts.
Code 125
TP sensor was lower than expected with the MAF/MAP value in the last 80 drive cycles.
Edit: here is a link to the video clip
http://video.google.com/videouploadf...6abfbab16f39d6
Old Apr 5, 2007 | 03:29 PM
StealthWyvern
Can anyone verify the codes being pulled? I know the cam ran out of memory at the end.
Old Apr 5, 2007 | 03:56 PM
quicklook2's Avatar
quicklook2
your codes refer to throttle position sensor.
the coolant bypass is probably not the problem.
Old Apr 5, 2007 | 10:47 PM
StealthWyvern
ok Thanks then it was by chance that it went out when it did. I juast wanted to make sure. I'll update this thread when I go to replacing the TPS this sunday.
Old Apr 7, 2007 | 07:20 AM
StealthWyvern
Is thier a way to replace the TPS sensor without takign off the throttle body on a 302?
Old Apr 9, 2007 | 02:34 PM
nighthawk285
no...........
Old Apr 9, 2007 | 09:06 PM
StealthWyvern
Thanks for your help guys. I repalced it this saturday without any issues other then the folks at advanced auto parts beind retards. They wanted me to purchase a "throttle body gasket kit" which is like 8 different gaskets which according to them is the only way that I would of recieved teh gasket that I was looking for! Needless to say my local ricezone(autozone) had the gasket for 2 bucks vs 25 or 35 at advanced auto parts.
I still have a hard shift but i'm guessing thats because of the motor and tranny mounts possably being dry rotted. So thats my next project.
Old Apr 9, 2007 | 09:22 PM
quicklook2's Avatar
quicklook2
did you reset the computer?
have you drained the trans?
Old Apr 9, 2007 | 09:25 PM
StealthWyvern
Yes I have reset the computer and the trans was jsut flushed a 8 months before I purchased the truck and was only driven a few miles literally sence then. I dont think the truck was driven a over 500 miles in two years so a lot of things are dry rotted on it. I've replaced a bunch of hoses and tires so far. I'm going to replace all vac lines here within a few weeks with the fancey colored crap as my gf calls it. lol
Conanski
31
Oct 3, 2023 08:52 AM
StealthWyvern
16
Mar 23, 2007 12:15 AM
twiztidfig
39
Feb 18, 2007 09:27 PM
kooper909
Dec 20, 2005 09:27 AM
nostranger2shame
Apr 12, 2005 06:41 AM
