Any suggestions on how to keep mice out my truck that sits a lot? I've tried the "spring scented soap" trick, but it doesn't seem to be working as well as I hoped.
Are you trying to keep them out of the cab, or the engine compartment? If it's the cab, stuff the cracks around every wire access hole in the firewall with pieces of "SOS Pads". They can't chew throught the steel wool and the soap makes 'em sick. If it's the engine compartment, well, how much do you like cats?
put moth ***** around truck and on axles tires .frame rail . I do this for my cars in storage . Just avoid putting them in cab. Because of smell. Good luck
I've always had luck with mothballs. i use them when i park my 96 for the winter. usally throw a few handfulls under the truck, put a few under the hood, and in the bed, tuck a few up under the frame. buy a few boxes of rat poisen and toss it around the outside of the vehicle
