seat belts
My experience is that of a surgeon. I've spent many a day trying to put non-seatbelt wearing "Humpty-Dumpties" back together again with their ruptured spleens, diaphragms, collapsed lungs, or ripped-up "whatever's". Telling a family that you weren't able to save their teenager is a SERIOUSLY bad day at work, and knowing that a seatbelt probably would have changed the outcome is particularly heartbreaking...
I'll not debate the finer points of what's better, because frankly, as was stated, nobody's going to crash-test a bunch of classic effies. We're all basically giving well thought-out, educated guesses. What I would BEG people to do is to put some kind of well-secured seatbelts in your truck and WEAR the bloody things! Someday it might make a difference...
Something we all take for granted till an accident claims a life just cause the lack of belt use.
The "olde style or aircraft" design belts I'm refering to that should NEVER be used had a large rectangular buckle with a side hinged face on one end and no metal parts on the other. The webbing strap was fed thru the buckle with the face held open and the end pulled to tighten. The buckle had spring loaded knurled rollers inside that gripped the webbing. I and the DOT recommend metal to metal buckles that release by pushing a button on the buckle.
I not yet had a problem w/ this style working as proscribed & I've only been in one accident while wearing one thank goodness.
You foreget something, I'm a Volunteer Emergency 1st Responce Medic, so that means I carry a Seatbelt Cutter in my Kit, which lives in my Truck, as well as one on my Key Ring, Res-Q-Me, & I've given one to every member of my Immediate family.
Really, the few sets I've seen just look like fender washers and a bolt. Is this all a guy needs? I"ve been considering going to the local metal shop and beg some 1/8" 3"x5" scrap instead.
http://cgi.ebay.com/ebaymotors/1966-...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/65-66...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/Vinta...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/1964-...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/1967-...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/Musta...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/Two-6...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/Seat-...QQcmdZViewItem
Basically, the heavy fender washers and bolt is the hardware kit. I also used a piece of 1/8 inch plate under the floor on mine to be sure the bolts don't pull through the floor...
I use mounting regs from SCCA as my mounting guide: All hardware must be no less than grade8 7/16" NF bolts, nuts, AND washers. Any attachment points that do not pass thru a structural member must be reinforced with a minimum 4" diameter x 1/8" thick steel backing plate.
suitable hardware can be obtained from racing gear suppliers and some online hardware
suppliers. If shopping the local sources be sure ALL the hardware is grade8.
Here is a link to racing harness installation specs and notes: http://www.gforce.com/pdf/harnessinstall.pdf
DO NOT use racing harnesses for street use, but the mounting geometry for the lap belt and shoulder straps should be noted.
Racing harnesses are meant to hold the driver into a properly designed racing seat. Except in direct frontal impacts it is the seat that provides the protection not the belts. With a standard OEM type seat a racing harness can CAUSE additional injuries in a highway collision.
I found this "off road" four point belt at Wesco Performance:
Wesco off-road belts
I have a pair of the model 50521-cse belts on order and will report on them when they arrive. The kit comes with snap ends, eye-bolts and 3" backup washers. They are also available with bolt-mount ends for less money. For an extra $8 you can even get a set in hot pink, just for the little lady. I like the fact that they mount to the floor. Based on AX's post about mounting, above, in lieu of the washers I'll probably put a single 1/8" steel bar, maybe 3” wide, under the mounting area.
I'm also curious what you guys that restore vehicles for show think of this solution. When you go to show the truck, the belts can be un-clipped and removed very quickly, leaving just three eye bolts as the only non-stock addition to the truck. How does the judging work for stock vehicles? Would the eye-bolts "cost" very much in terms of points or however the rating system works?
AX,
I'm very interested in your comments on this type of belt. I see what you say about how a racing belt could limit your movement. I can just reach reverse on the 4-speed transmission without moving my shoulders from the seat, but I have gorilla-length arms; a lot of folks would not be able to reach. I’ll have to have a little slack in the shoulder belts to be able to check my blind spot (I have the small rear window in my pickup). We’ll see when the belts arrive next week.
Cal
Well, I think the server is messed up. It keeps telling me that I have to enter more than 10 characters...
