88 351 koeo codes
Old Mar 16, 2012 | 12:14 PM
88dually's Avatar
88dually
88 351 koeo codes
These are my codes
Koeo
85
Koer
41
Do i have a bad egr valve an o2 sensor ?
If the truck sits overnight, wont start unless i shoot ether at it. If i push the gas pedal hard an to floor, it stumbles like its gonna stall, sometimes it'll pop like timing chain jumped a tooth.
It also has a blown head gasket.
Old Mar 16, 2012 | 01:43 PM
subford's Avatar
subford
More than likely no to both questions.
Service Code 85 indicates a failure in the CANP solenoid circuit.
Service Code 33 in Key On Engine Running indicates that the EVP sensor input did not change after the EVR solenoid was instructed by the processor to open the EGR valve. Because a Code 84 was not received in the Key On Engine Off Self-Test, it is known that the EVR solenoid functions electrically. It is also known that the EVP sensor is in the expected closed valve range because Code 32 and 34 were not received in either Key On Engine Off or Key On Engine Running Tests.
Service Code 41 system indicates lean.
Service Code 12 indicates that during Engine Running Self-Test, engine rpm could not be controlled within the Self-Test upper limit band.
timemachine455
Sep 1, 2018 06:57 PM
truck crazy man
35
Feb 12, 2016 08:14 AM
manutd1910
18
Jan 15, 2015 03:09 PM
btorear
Sep 5, 2009 12:27 PM
DJdemon6696
May 18, 2007 05:25 PM
