heater working too good to be true
Hi gang. I don't know if this is a problem or not. In 30,40 degree weather or any other temp for that matter, with in 5 minutes of starting bronco, it is throwing heat from the vents. All the heat controls are working proper. I don't see how it is possible to get heat that fast. Could this be an indication of a problem with the cooling system? The temp guage never goes past the first line of the word normal: NORMAL
Is this normal for bronco's or do I have a problem some where that I need to fix?
After driving awhile there is presure in the radiator, I pull the lever on the cap and the pressure releases. The antifreeze is up to the neck.
Any info would be appreciated.
Bill
<!-- / message --><!-- sig -->
Bill
Originally Posted by captradiator
Bill,
Keep in mind that those factory gauges are supplied by the lowest bidder. If you have access to a non-contact pyrometer, take a reading as close to the T-stat as possible and you should get a temp. within ten degrees of 195.
Calvin
heater works too good
Thanks for all the info. A guy at work has one of those infra red type temp sensors, i'll have to borrow it. So the low temp guage reading could be the sensor itself or most likely the guage. If its the guage, then the only option would be to get an aftermarket guage and mount it in or under dash.
One other question about the thermosstat. My bronco's original owner lived in Hawaii. Would the very warm climate dictate what temp thermostat was installed in the bronco or is it the same no mater what the climate?
thanks
Bill
thanks
Bill
Bill,
We have repaired a few gauges by just changing the sending unit (Use OEM only!). The very best thing is to install a quality aftermarket gauge.
As far as what T-stat came in the truck, the T-stat is part of the smog/emissions package, so 195 should be what came from the factory, no matter what state it was delivered to.
