Wheel Bearings???
Old Apr 2, 2007 | 08:07 AM
TD2000Merc's Avatar
TD2000Merc
Wheel Bearings???
Hey guys, does anybody know when you are supposed to repack the wheel bearings?
Old Apr 2, 2007 | 10:44 AM
patho44's Avatar
patho44
every 60-80k is a good interval.
Old Apr 2, 2007 | 03:38 PM
mrshorty's Avatar
mrshorty
What year? Front or Rear? '91 to '94 use a serviceable front bearing that can be repacked at regular intervals as suggested. '95 on up use a sealed bearing unit that can't be serviced and just gets replaced when it goes bad. '91 to '01 rear is a semi-floating axle in which the bearings are lubricated by the rear gear oil. Other than drain and refill the diff fluid, there's usually no need to perform other maintenance on the rear bearings. I'm not at all familiar with the '02+ rear setup, so I don't know what maintenance that needs.
Old Apr 2, 2007 | 03:49 PM
TD2000Merc's Avatar
TD2000Merc
thanks mrshorty, looks like i would have to replace entire unit on my 2000.
Old Apr 2, 2007 | 04:44 PM
steve(ill)'s Avatar
steve(ill)
the newer 4 wheel independant suspension systems have sealed bearings and hubs in the back very similar to the front. backs are a little harder to change out than the front hub-bearings.
Old Apr 3, 2007 | 02:18 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
Yes the 2000 is a sealed assembly. Pretty simple to replace though.. just a few bolts. Unfortunately the part isn't cheap.
Good luck
Old Apr 5, 2007 | 11:20 AM
ltng7679's Avatar
ltng7679
What's the symptom of bad bearings?
I'd hate to wait until the wheel falls off.
Old Apr 5, 2007 | 12:19 PM
mikeinri's Avatar
mikeinri
This might sound too obvious, but have you checked the maintenance schedule in the owner's manual?
Mike
Old Apr 5, 2007 | 05:03 PM
steve(ill)'s Avatar
steve(ill)
when the bearing starts to spall it will make a small whinning noise. in a couple months it will be irritating inside the truck. it will howl after 20,000 more miles. dont worry, it wont fall off. you will get tired of listening to it and change it out before it ever failes in a critical manner. the owners manual dont say crap about the bearings, they are sealed for life and not maint can be done. what you determine is the definition of "life". i have a 96 that had one side go at 155,000 miles. i had a 2002 that had one side go at 85,000. i have a F150 with 160,000 and no problems to date. it is not a definite number on "life".
Old Apr 8, 2007 | 10:06 PM
daggerNC's Avatar
daggerNC
Do I have bad bearings as well? My 2000 XLT 4dr, 4WD has 108K miles. New Michelins about 10K ago with new alignment - I see no evidence of any uneven wear. The truck starts to make a road noise that begins around 18mph, reaches maximum intensity around 44mph and drops down after 50mph. The sound is like some others have said in that it sounds something like I have very large mudders on. I can put the truck in neutral while moving- no change. Putting it into AWD has no effect. Turning left and straight has the sound - but turning right reduces the howl. The sound appears to be coming from the front (maybe left, but can't be sure). I've replaced the rotors before and know that this has the sealed bearing assembly. Before going thru the expense and labor or trying to replace - can I get some feedback on the likely cause? If it is a bearing assembly, then would Advanced Auto or Pep Boys be a better source than Auto Zone?
Thanks,
daggerNC
Old Apr 8, 2007 | 10:21 PM
steve(ill)'s Avatar
steve(ill)
jack up the front end and take both brak calipers off. rotate each "hub' several times with a bar stuck between the lug studs. if one side gives a grinding or whizzing noise, then that is the bad one. compare both sides to get an idea of what is "normal" and what is "abnormal" it dont take a lot of noise at this low speed to make quite a racket at 50 MPH. I bought a hub thru e-bay for $100. for the front. It is twice that at Auto Zone. I would guess all "parts" stores have about the same price. Just make sure you buy the correct year hub.
Old Apr 9, 2007 | 12:49 AM
f2fitty's Avatar
f2fitty
Believe it or not, I found the Stealership to be the cheapest of all the parts stores. Go figure. Good Luck, Fitty
Old Apr 9, 2007 | 12:15 PM
daggerNC's Avatar
daggerNC
If I recall, to remove the hub that's the large nut that has to be removed - and what, about 125 lb-ft to put back on? I'll jack it up and test as per steve's procedure. f2fitty - guess I'll check with my local Ford dealer for the part - thanks.
Old Apr 9, 2007 | 05:12 PM
steve(ill)'s Avatar
steve(ill)
the "hub" is actually a steel casting that bolts to the A frame with 3 metric bolts in a tringular pattern. the bearing presses into the casting and the "hub" is pressed into the bearing. .this allows the hub to rotate the casting with the bearing to remain stationary. the big nut holds the splined alxe into the center of teh hollow hub. you need to get the "big nut" off and also the 3 metric bolts that hold on the hub-casting, those are the tough ones. get an AMERICAN 6 pt -15 mm - box end wrench, and a 5 pound hammer to assist. I have a special CRAFTSMAN wrench i use to remove the bolts. they are loctite into place and some are about 250 ft pounds to break loose.
Old Apr 9, 2007 | 09:29 PM
daggerNC's Avatar
daggerNC
Thanks steveill - this sounds like its going to be a fun job......
RAPTORMATT
2009 - 2014 F150
Oct 11, 2016 10:23 PM
ItsAFord55
Nov 20, 2015 02:24 PM
swampfire79
Sep 26, 2012 10:13 PM
paker
1997 - 2003 F150
Feb 19, 2011 01:15 PM
Toyman
Aug 20, 2008 03:41 PM
