[font=Times New Roman][size=3]If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter.
If someone can come up with the distributor number for a 1970-71 390 in a full size car I can probably come up with the advance specs. A pre smog 390 may make a good starting point for your advance on a 360. The number would be something like 12127-XXXX-Xx
Okay well back to the distributor swap. Has anyone ever tried the procomp ready to run electronic distributors with the vacuum advance #pc 7002? If so how did it go for installation and did it work? What would be the best coil and ignition box? This is for my 78 F100 302w
I never had good luck with the Ford Duraspark ignition. I've owned three Ford trucks and a CJ7 Jeep all with Duraspark. Always had intermittant problems at the worse time. The modules seemed to fail whether they were factory or aftermarket parts. I switched to MSD and I don't have anymore problems. I had about ten modules at one time. They make nice rifle targets.
