trans ???
Old Apr 5, 2007 | 07:28 PM
ron's power stroke's Avatar
ron's power stroke
I thought of picking up some electrical clean and clean my c-103 plug..i finily found a ride ..when I washed my truck Sunday I power sprayed in by the oil filter and cooler to clean things up..I went down town and my truck stumbled a couple times.so when I got home I let it idle to dry out.i figured i got something wet..that after noon is when the TC stopped working...so today I came strait home and cleaned up the plugs and took it out for a ride...it shifted perfect...no slip no nothing...just a solid shift into the next gear..I'm so damn happy..could this be a fluke??? please say no..lol...I took her to a local Trans shop..he drove it with his snap on computer and said that trans is fine..he did recommended I do a flush to the Trans...he has a machine to do this..he also recommended using synthetic Trans oil..I'm not to sure about that...I was told synthetic could cause the Trans to slip more..what are your thoughts??i will be adding the trans filter from bob at diesel stite but should i do the flush with his machine??should i use synthetic oil?? thanks guy's..
Ron
Old Apr 5, 2007 | 07:55 PM
Uzumati's Avatar
Uzumati
Ron get the flush valves with bob's tranny filter and do it yourself (see right up on 7point3). I have been using royal purple MAX ATF (synth) with no problems in tranny and power steering.
Old Apr 5, 2007 | 08:08 PM
ron's power stroke
thanks Alan..that valve looks good for 20 bucks..are you talking about the 20 qt ATF change??? how does that valve help power flush??
Old Apr 5, 2007 | 08:15 PM
Uzumati's Avatar
Uzumati
Yea the 20 quarter. It just makes it easier so you dont have to discconect the lines. You remove a plug and open the valve.
Old Apr 5, 2007 | 08:45 PM
ron's power stroke
thanks again Alan..would this do as good of a job as the power flush from a shop??this Trans has 166k on it and the pan was only dropped once that I could tell..that was at 155k when I did the bts vb..that was just a new filter and 9 qts..I was just getting ready to do it again when this all took place..when I did the BTS my pan looked like fly west pan ..if you can remember??..there was a lot of slug and fine shavings.the fluid was a little brown and a slight bunt smell...other then this time with the TC.. this Trans has never missed a beet..always shifted good..maybe a power flush from a machine now would be better?? then keep up with the maintenance useing Bobs valve to do my flushes..or would that be a wait of cash?? thanks again Alan..
Old Apr 5, 2007 | 09:02 PM
Uzumati's Avatar
Uzumati
either way will work fine, but even after which ever flush you choose get an extra filter and change it after about a month just to check for accumulation.
Old Apr 5, 2007 | 11:05 PM
ernesteugene's Avatar
ernesteugene
Ron
Sounds like the "c-103 plug" might be the one on the drivers side where the cable from the manual column shifter plugs in to the tranny? I know from experience that the main body connector on the passenger side of the tranny is subject to water intrusion.
That male connector on the tranny is oriented vertically like a cup, and it can get full of water. I had a Banks trans command installed at Camping World long ago, and they screwed up the O ring that seals that connector and soon after water got in there from running through a deep puddle, and my OD light started blinking and shifting funny. I had to soak up the water in the connector using a number of Q tips and working them down around the pins, then I sprayed it out with CRC circuit cleaner and let it dry good, then reassembled using dielectric grease.
You might want to check my Post #5 What I learned about dielectric grease (DG) from a Ford tech!, for how I addressed the problem of keeping water out of all the connectors under my truck. https://www.ford-trucks.com/forums/592457-flashing-od-light.html?highlight=dielectric+grease
Old Apr 6, 2007 | 03:30 AM
ron's power stroke
thanks for the info ernesteugene.ill check the connector on the passenger side tonight...I have a tube of that I use on light bulbs and I did use a small amount on the cps sensor..I thought too much would mess things up too..but it sounds like I better do all my plugs like that..I need to wash under my hood here soon..all though we are still getting snow..over 13 inches since last night..under the hood is just gray powder from road salt..I'm just glad my TC fix was a cheap fix..now its time to save and get me a new Trans..thanks for your help ernesteugene and Alan..
Old Apr 6, 2007 | 11:19 AM
ernesteugene
Well, like I said in my original post I was also concerned that too much dielectric grease might screw up an electrical contact. When I did all my under the truck connectors by filling them full of the stuff I was still in the Ford garage, and it was with the assurance from the Ford tech to do them his way, and if when we took the truck for a several mile test ride to check out the new IDM he would trouble shoot and fix any bad connector problems.
Well, everything worked fine and I haven't had any reason to touch any of those connectors since then. I see a clear advantage of filling every available space with grease so no moisture can penetrate the connector but.....there's always Murphy's Law? Bottom line is it worked ok for me, but please don't blame me if it doesn't for you. Maybe a thread to get other opinions is in order?
