88 F150 Ride Height Difference
Old Apr 1, 2007 | 08:38 AM
Phillip Guidry's Avatar
Phillip Guidry
88 F150 4.9 4-spd Man. 2wd Reg Cab LWB A/C
What is the ride height diiference between front and rear on a good set of factory springs ? I've got a 3in. diiference now.I want to get new coils for the front.....but if i get the 2.5" coils and I should only have a 1" diiference with factory springs....I'll end up with the front higher then it should . I saw recommendations on the CC824 and CC826 springs here.......also looking at those 1.5" & 2.5" coils by rough country.
Thnaks,
Phillip
Old Apr 7, 2007 | 02:35 PM
Phillip Guidry
No replies yet ?
Thanks,
Phillip
Old Apr 7, 2007 | 03:05 PM
lostin90s's Avatar
lostin90s
I use heavier F350 coils depending on amount of sag .(if the truck would sit decent ) you are looking at an 1 in -1 1/2 lift (most truck coils are sagged that much ) . I take it you have overloads or after market springs on back ? I have seen truck sit like yours that the front springs were just shot and had stock in back . The 2" lift spring was to much . Give us A little more info on your rear springs . I bet the 2 1/2 would work though. Good luck
Old Apr 7, 2007 | 03:13 PM
Phillip Guidry
When I go outside,I'll look for the spring codes in the door jamb and report back. It had air shocks in rear until last weekend.....put normal shocks on it.......then I measured the heights between the tires and wheel opening. Should I measure somewhere else for you ?
Thanks,
Phillip
Old Apr 7, 2007 | 04:02 PM
Phillip Guidry
Spring codes in door read C D ? Rear leafs look stock...no extra spacers or add on's that I can tell.
Phillip
dooger54
2015 - 2020 F150
42
May 10, 2016 07:20 AM
SkiBikeClimb
Sep 2, 2014 10:17 AM
panningbros
Feb 16, 2010 07:57 PM
jj292
Paint & Bodywork
Nov 7, 2003 12:03 PM
